When i try to power up the computer it cant come on but the light on the motherboard comes on.what could be the problem? i tried to change the Power supply with a good one but still was facing the same problem,also tried to remove the memory chips then put them back, still the same problem
  • 124 Answers
Very simple the problem is with ur motherboard checkout the mosphet and capicitors located near the cpu socket . its due to mosfet or capicator failure. ok take multimetter and check out it will definetly solve the problem
Posted on Apr 01, 2011
Light on power supply thing on back comes on but cant turn computer on, light on the front does not turn on
Id first replace the power supply for around 30 dollars from www.newegg.com . The power supply will still hold power even tho it may be bad which is why the light is still on. If you need further help just e-mail me.
May 05, 2011 | HP Pavilion A6720F Desktop, 2.2 GHz AMD...
I have an rdx 200 motherboard brand new but I cant load anything not even bios 4 diagnositc lights show up.
try a new power supply first. There is a light on the board that comes on when the power supply is plugged in.
May 20, 2010 | DFI LANParty UT RDX200 CF-DR Motherboard
System will not boot the motherboard gets power the green light on the mother board comes on and the hard drive has a green light that comes on there is no beep though. I fooled around with it and it...
Remove your ram and put it back again. Sometimes this helps, otherwise check if your power supply is giving enough power to run the board and all of the components.
Hope this helps!
Please rate!
Cheers
Sep 27, 2009 | ASUS P4GE-MX Motherboard
Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Aug 11, 2009 | Dell Dimension 2400 PC Desktop
Cant boot my system
Check all your power cable if they are losened and the memory if is fully inserted
Aug 04, 2009 | ASUS P4SDX Motherboard
No video mouse or keyboard but all power and leds are working
there are several problems to this case.
1. check the 24 pin power supply and be sure to plugin the 4 pin power supply just beside the cpu.
2.ram not placed correctly
3.Power supply inefficient.
4.BAD BIOS SETTINGS Try resetting bios i.e.., CLEAR CMOS or remove onboard battery, wait for a while and then place it again.
5.RAM is damaged
6. Highly overclocked cpu - resetting bios works
Check all the above to see whether your computer comes online.
6.
Apr 22, 2009 | ASUS P5GC-MX/1333 Motherboard
Power supply or motherboard?
your motherboard BIOS is corrupted you need to replace it...
Mar 10, 2009 | MSI 865PE Neo2-V Motherboard
Power On trouble with Computer
If don't you have any beeps check maybe the power button stack.
If the power button pressed for four seconds then the computer normaly shut down.
Jan 11, 2008 | Abit KV7-V Motherboard
Power in motherboard but cant turn on
Try removing the memory and turning the system on. If it starts to beep you may have faulty RAM.
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
