Question about Refrigerators
Samsung model rsh1dbbp: fridge running at 19 degees. have cleared ice build up in lower left hand side. freeer and water ok. no ice build up in freezer
  • 132 Answers
The accumulation of ice on one side indicates a refrigerant problem. Basically there is a refrigerant leak and some of the refrigerant has been lost.
A technician can repair the leak and re gas the refrigerant for you.
Posted on Apr 01, 2011
Testimonial: "thanks for identifying problem. will get technician out to repair"
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
Samsung fradg
When you thaw or let the ice melt, make sure all the vents between the freezer(upper compartment) and refrigerator(lower compartment) are clear of ice or obstructions. This is very important! Make sure all vent ducts and tubes are clear of ice!!! Next Level the unit front to back and side to side. Make sure the refrigerator is level. When level the doors should close without assistance. It is normal for water build up and dripping sound in the fridge do to condensation, the air vents and an evaporation pan located behind the cover in the rear of the freezer will eliminate the water if unit is properly leveled. I had the same problem, then i read the user manual. this will also eliminate all the water in the lower compartment.
Jun 28, 2013 | Refrigerators
Rubbing noise on fridge side - ice build up behind lower panel
The rubbing noise comes from your build up of ice. If no auto-de-icer, then unplug your fridge or turn it off, allow it to thaw, remove all dripping water. restart or replug
I use a shop vac to remove water.
be sure NOT to break, or chip the ice, as you may break freezer components
Dec 18, 2010 | Samsung Refrigerators
Defrost works fine but ice builds up in return air channel and fridge gets warm. model 106.55622500. Fan Ok, no ice on coil after defrost defrost timer ok. settings on middle of range after 3 weeks ice...
Hi!!
You may have the temp. set TOO HIGH for the freezer, set it in #2, leave the fridge setting in the mid range for now. Check after 24hrs. and adjust as necessary.
Good Luck!!
Mar 20, 2010 | GALAXY Microsystems 25.4 cu. ft....
Water leak front left corner of freezer.
Your defrost drain line in the freezer is frozen closed.
You must turn off the fridge.
Remove the visible ice.
Use a hair dryer at the drain opening in the lower back of the freezer to melt the drain line ice.
Mar 11, 2009 | Electrolux Refrigerators
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Ice in bottom of fridge
ok Your defrost drain is frozen or has algae blocking it it’s at the back of the freezer behind the evaporator cover. You can see it without removing the evaporator cover. You might or might not see the drain hole because of the ice now you can sit and poor hot water on it till it thaws then get a thin wire and run down the tube till its clear or sit there with a hair drier and thaw it .But if you don't mind a small investment ill tell you the best way to deal with it .Go to Lowe's or some where like that and buy you a eureka model 350 hand held steamer. Trust me it will be one of the best investments you'll ever make. You will find 1001 uses for it besides this and the steam will not damage your refrigerator and all the attachments make it very useful. Remove the evaporator cover and take the steamer and melt the ice under the evaporator where the drain pan is. Then you will see the drain hole. Put the curved tip on the steamer an start clearing the drain hole now when you get it melted enough to where the curved tip makes a seal around the drain hole let the steam build then hold down the trigger till you hear it at the back of the refrigerator and your done put the evaporator cover back on then think of all the other uses for that steamer now I told whirlpool about it they tested it and now have it posted on their web site
Mar 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
547 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
