My printer cannot print any more.Error gives out is 49.0665 service error.plz assit me.printer is hp laserjet 4350dtn.
5 Suggested Answers
pdouglasss
  • 125 Answers
SOURCE: support
49.XXXX
PRINTER ERROR
To continue turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort the operation.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the printer. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 Service
Error
1 Press CANCEL JOB to clear the print job
from the printer memory.
2 Turn the printer off and then on.
3 Go to www.hp.com/go/lj4200_software,
www.hp.com/go/lj4250_software,
www.hp.com/go/lj4300_software, or
www.hp.com/go/lj4350_software.
Select Download Drivers and
Software
. Check for the latest firmware
image version at the bottom of the
page. If this firmware image is newer
than the one installed on the printer
and the printer can receive a firmware
update, download the newer firmware
upgrade. Not all
HP LaserJet 4200/4300 printers can
receive firmware upgrades.
4 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file.
hope this helps you
pdouglasss
Posted on Jan 10, 2009
  • 14 Answers
SOURCE: hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
Posted on Jan 27, 2009
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
seeker5211
  • 1089 Answers
SOURCE: 49.FF95 Service
It's a critical firmware error. Try printing another job. If that one works, something is corrupt with the first job. Still failing remove any extra DIMMs from the formatter. Don't remove the one in slot J1. That's the firmware DIMM. try to print. If it works, reinstall the DIMM and try again. Failure = bad DIMM. You may want to try a firmware upgrade. If everything keeps failing you'll have to replace the formatter.
Posted on Oct 05, 2010
Hp Laser Jet 4350dtn network printer is showing Service Error 49.4C02 how do I fix
Does it occur on any print job or one in particular. If it happens with one job, that job has a problem. It isn't the printer.
If it is all printing go the www.hp.com. then go to "support and drivers". Then select your printer, select your operating system, select firmware. Upgrade your firmware. Make sure that you read the instructions and DO NOT touch the printer while it is upgrading.
If the firmware upgrade completes and the errors continue, you will need to replace the formatter.
Dec 23, 2010 | HP LaserJet 4350dtn Printer
49.FF95 Service error in HP Laserjet 4350dtn printer. Pls help me what is the exact error.
Oct 05, 2010 | Office Equipment & Supplies
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Jan 05, 2010 | HP LaserJet 4350dtn Printer
Printng error
Please change the driver to UPD (http://www.hp.com/go/upd) to PCL5
This will solve the issue
Rgds,
Nikhil
Jun 14, 2009 | HP LaserJet 1320n Printer
Service error 49.4C02
General 49 errors are formatter related. It can be caused by software, bad memory. See if you can isolate if its one app. maybe even one document that has a problem. If all cause swap the dimms except the lowest 2 which are the firmware. And try. Next Print config. Check firmware version and call HP to see if there is a revision upgrade. Last and most expensive is replace the formatter.
Jun 12, 2009 | HP LaserJet 4350dtn Printer
4350dtn 41.3 error..help!
It sounds like the registration switch actuator is being held down too long.
Also check registration clutch and make sure cassette tray is lifting all the way up and feed rollers are "snapped" in tight. Good luck.
Weird problem!
Feb 05, 2009 | HP LaserJet 4350 Printer
53.10 Error "Shut off printer and turn back on"
The error points to your memory see below. the .10 indicates internal ram. You may need a formatter bd.
53.XY.ZZ PRINTER ERROR To continue press cancel job Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
  1. Press Cancel Job to continue.
  2. If the problem persists, turn the printer power off and then turn the printer power on.
  3. It might be necessary to replace the specified DIMM. Turn the printer power off, and then replace the DIMM that caused the error.
Jan 20, 2009 | HP LaserJet 4350dtn Printer
PCL XL error
Please uninstall the current PCL driver and upgrade the same with UPD PCL5 (dont install PCL6) from http://www.hp.com/go/upd
Regards,
Nikhil
Dec 16, 2008 | HP LaserJet 1320n Printer
3,748 people viewed this question
k24674
jasbo
jasbo
