Question about Denon AVR-2500 Receiver
The protection mode keeps coming on every time i turn it on I have a denon AVR 2500. can anyone help?
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Apr 01, 2011
Why does my new AVR X1000 keep going in protect mode
It only goes into protect mode usually when there are to manny speakers hooked up more then its can handle
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
I have a Denon AVR 1601 that cut out in the middle of a song. It will now not turn on, it starts and then cuts out
It went into what is called the protection mode,Did you have it cranked up loud when it happened,? Check if any of your speaker wires come off some how end are crossing . Or there could of been a power suge that will also cause it to go into the protect mode, End fried internal parts on it.If it is a internal problem. The repairs will be verry expensive if it can be (Repaired) A lot of times it is cheaper just to go end buy a different one.
Oct 20, 2012 | Denon AVR-1601 Receiver
Protection keeps coming on,Please help me,thanks!!!
unhook everything going to it, including the speakers,, then turn it on, if you get the same thing, its going to have to be taken to a tech to probably replace the output transistor
Jul 22, 2011 | Denon AVR-2500 Receiver
Amp comes on and goes right into protection mode I turn on my Denon stereo receiver AVR-1500 an it goes to protection mode? Can someone please help me?
Do you still have the AVR1500? I have one with a bad tuner--and would be interested in purchasing your for parts. Let me know if you still have it and if you'd be willing to sell it.
Dec 01, 2008 | Denon AVR-1500
Denon AVR-588 Sound Delay
FIRST, IF YOUR USING HDMI CONNECTIONS IN THE DENON HDMI SETUP YOU HAVE TO TURN THE AUDIO DELAY ADJ. ON
SECOND, THE DELAY TIME ADJ, FOR OTHER SOURCES IS LOCATED ON PG 27 IN THE MANUAL, HERE IS THE LINK TO DENON SITE WITH MANUAL
http://www.ca.denon.com/AVR-588-OM-E_102.pdf
Jul 12, 2008 | Denon AVR588 Receiver
My protection light keeps turning on when my speakers try to start up
Your audio amplifiers IC's are damaged you gotta send your device to a repair center.Good luck.
Jun 02, 2008 | Denon AVR-2500 Receiver
What failed component causes protection error message to display right at power up.
well, i just got this thing from a friend. its a Denon AVR-800. when powered up it displays the stops, just before finishing a -protect- shows up. There's a little red light standby light that blinks off and on also. i think that has to do with the internal problem. any suggestions?
Apr 03, 2008 | Audio Players & Recorders
Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Jun 05, 2007 | Denon AVR-2106 Receiver
193 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
