Question about Sport & Outdoor - Others
We have a elliptical trainer Model OBE2I and it keeps coming up with ERR4 on the display screen and cant change the programs or enything I would like to know 2 things #1 how to fix this problem #2 and why is this happing
SOURCE: the program monitor on my eclipse 1100hr/a
After about 4 years, one day my monitor just wouldn't turn on. After making sure the batteries were new, I took out the four screws on the back of the monitor and made sure the two wire connections were tight. They were, so I called Fitness Quest customer service (1-800-321-9236) from their website (fitnessquest.com). For about $120 including shipping they sent me a new monitor. It took me about a minute to undo the old, plug in the new, and now it works great! The flat connection with the multi-colored wires requires a gentle squeeze with a pliers on the sides while you glently wiggle and pull it apart. Look at the new connector to see how it should come apart. Good luck!
Posted on Jan 16, 2010
maxtreadmill
  • 832 Answers
SOURCE: tunturi elliptical cross trainer error e-2
Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to http://accellfitnessna.com or Email a.parker@accellfitness.com they will help you they Tunturi Distributor of North America
Posted on Apr 11, 2010
mastermaid
  • 502 Answers
SOURCE: I need to download a user manual
go to http://manualfox.com/link/reebok.htm
- they have the manual available for download (REV-10211)
Posted on Jul 06, 2010
micromatikal
  • 2777 Answers
SOURCE: I need the instruction booklet
That is going to be virtually impossible to obtain online, you will need to contact Confidence to obtain this manual. I believe their number is 1-800-887-7161
Posted on Oct 01, 2010
  • 3 Answers
Check it out. If you machine monitor shows and e-1 when trying to turn on. Take out the batteries and unscrew the four screws on the bottom of the monitor unplug it from the elliptical. Put the batteries back in turn on monitor the plug it back to the elliptical while still on and screw back in places. It worked for me hope it works for you too.
Brian Pickens
Long beach ca
Posted on May 04, 2011
Hello, I've just bought a Voit Eco Elliptical cross-trainer - had it set-up - and have used it once. Now it doesn't work, at the 2nd work-out! The screen indicates 'ERR4'. I've tried to reset it, stop...
Hi Belinda,
I know someone who was seeing the same error and also tried resetting the computer on the machine but did not work. As per what they told me it was some issue with the Motor. And they could replace the motor under warranty and the issue was resolved. you can try doing the same thing if nothing works. cheers.
Aug 21, 2013 | Exercise & Fitness
Hello, I own a Schwinn Elliptical 430 which I keep outside, covered with a tarp, since 2011. It's been fine till now, the "Enter" button isn't responding so basically I can't use it because I can't move on...
HI,
Its probably because of the enter switch is not activating. Its contacts gone bad. There will be push switch behind the enter pad that you see from the top. you have to replace this by opening the Console, Display. if you are able to do the same please let me know .
Or just remove the Console, Display and take it to the nearest electronic rearing shop. They can do it very easily. and it will not cost a lot too.
Ajin
Aug 17, 2013 | Schwinn 430 Elliptical Trainer
I know that elliptical trainers are a good cardio workout but do they allow you to work your upper body?
Most elliptical trainers nowadays come with moveable arm handles. This gives you more upper body endurance and allows you to burn more calories.
Aug 02, 2012 | Exercise & Fitness
Do elliptical trainers have adjustment qualities?
Yes. Most trainers have adjustments for elevation. The elevation feature on an elliptical doesn't make the workout harder; instead it changes the emphasis so that the higher the slant, the more your glutes and hamstrings will be worked out; whereas the lower positions emphasize more on your quads and calves.
Change batteries in consol of elliptical, but still the resistance or tension does not change or increase
their maybe a loose connection between the upper display and function controls I would pull apart the upper display and check the connectors between the two boards
Feb 28, 2010 | Precor EFX 546i Elliptical Version 4
Sport & Outdoor - Others Logo
70 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
