Question about fuses
Is a Slow-Blow fuse the same as a timelag?
  • 1,512 Answers
Yes. the Germans call them time lag :) In Australia, we shorten it to SloBlo.
robotek
Posted on Aug 05, 2008
Pioneer 74txvi fuses (fast or slow) burning
If there is nothing left inside the little glass tube, it's a fast blow. A slow blow fuse will usually have a spring and some other material that make up the slow blow mechanism. slow blow fuses used to also have 'SB' stamped on the metal end caps. The fuse holder may also tell you. If you cant figure it out, put in a fast blow and see how long it lasts, If if blows when you turn the volume high, you should try a slow blow.
Jan 22, 2015 | Pioneer Audio Players & Recorders
Can i use another 4a 250v fuse for my cerwin vega LS12 if its not a (slow blow) ,and what would be the outcome
Fuses have different blow characteristics. Such to protect components differently. An extremely fast fuse would protect sensitive components like tweeters and slower fuse will allow transcients to pass and blow on long time fault. If you put a slow blow in place of fast blow, it won't blow as quickly, but it could allow the protected device to be damaged. In reverse, you put a fast blow in place of slow blow, it will blow at normal transcients and be a nuscience to always replace.
You can cross to a fuse of different manufacturer. The reliable manufacturers will have detailed datasheet and subsitute or similar fuse to the fuse you are looking for.
Oct 23, 2013 | Cerwin Vega LS-12 Speaker
Does The Onkyo TX-8210 take a slow blow or fast blow fuse?
slow blow (aka time delay) fuses are used in motor circuits. Electronic devices use normal or fast blow fuses
Oct 02, 2009 | Onkyo TX-8210 Receiver
No Power on 32" Panasonic
A slow blow fuse is also known as an anti-surge fuse the idea being any sudden "spikes" in you mains electric when you switch on would blow a quick blow fuse. Anti surge fuses are designed to tolerate any sudden initial electric pulse.
Jun 22, 2009 | Panasonic CT-32SL14 32" TV
PC power supply fuse - T6.3h 250v engraved on end
T = time delay (slow blow)
6.3A = 6.3 Amperes maximum load
H = HRC - high rupture current (as you specified a ceramic fuse)
250V = 250V AC rated
other letters you may see
FF = ultra fast blow
F = fast blow
M = medium blow
TT = very slow blow
L = low blow current
H = high blow current (glass package)
S = sand filled
Apr 02, 2009 | Dell Computers & Internet
Can a internal slow blow fuse be fixed?
Any internal slow-blow fuse can be replaced with one of the correct value. Fuses do seem to have a finite life, so occasionally you can just replace the blown fuse  with an identical one and all will be well. However, fuses are protection devices , and it's more likely that you have a  short circuit or  defective component in your VS3251 that's causing it to draw too much current , and the internal fuse is blowing to prevent further damage. ie the fuse blowing is the symptom not the problem. Never replace fuses with ones of a higher current rating. Slow-blow fuses have the suffix T (for "Time Delay", and normal ones have F ( for "Fast"). With the street price of the VS3251 , a commercial repair is uneconomical
Feb 01, 2009 | Electronics - Others
6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
26 people viewed this question
 Grubhead
Grubhead
