Question about Philips Magic5 Voice DECT Duo - Fax / copier - thermal transfer - 50 sheets - 14.4 Kbps Plain Paper
There is a "sun" sign
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 37 Answers
The sun sign is unrelated to the problem. the sun signifies daytime setting pertaining ringing sound asf..
press DIAL immediately and listen whether it is engaged. If yes, fix your phone line.
if no, dial manually. if still unsuccessful come back here.
Posted on May 11, 2011
Phone doesnt have dialing tone, cant make a call also when we ring home its goes to engaged tone
This means that your phone line is short circuited somewhere.
The technical name for it is Partial line Lockout.
Try unplugging anything connected to the phone line, including modems, fax machines, house alarms etc (as faulty equipment can cause this), then try ringing home again. If it now rings, plug things in 1 at a time and ring each time to see what is causing it.
If it is still an engaged tone with everything unplugged, then the short circuit is on the phone line in the street and needs to be repaired by your telephone company.
Oct 11, 2014 | Lands Phones
HP Officejet 6500 no longer hears the dialtone. The line works fine with a regular phone, but not the printer. Up until a couple of days ago, it worked fine. The printer says the line is in use (wh
Usually on hook telephone line voltage around 40V DC +/- depends on exchange, voltage will drops below 12VDC if its half hook..You will get engage tone/usage tone if voltage drops less than 12V, in this condition you wont get any incoming calls.
You need to open the printer formatter to locate the modem where telephone line inserted..
Let understand why this malfunction happens..
The ring voltage between the line is +120V AC, but it should not exceed more than 200V.. To protect the circuit, line will guarded by component called "VARISTOR". The Varistor will burns if voltage reaches specified or more voltage across it.. Once varistor burns U will get engage tone always... Basic multimeter is enough to check the varistor, put multimeter in diode mode, test both ends of varistor, it should not show zero value or beeping. Some times it may burn, blast or bulge. Remove the faulty component from the circuit with the help of soldering iron, connect the line & verify, if line is good replace with same rating of component.. Chk for the ring & dial tone...
Req tools: Multimeeter, soldering iron, little paste & Led, screw driver set for opening the printer..
Depends on design varistor may fix accordingly which we need to find out the location.. But its always fixed between line in path. pl see the attached sample diagram.
if you are non technical pl don,t try it...Best of luck.. 6f4a7950-5cc9-42c6-bb47-b2ba2007add0.jpg 21aa8d50-de72-49d9-a692-6c813c2c0768.jpgEx: Varistor ac224650-2c77-4de1-934f-929cbd6f0d15.jpg Damaged/burnt varistor
Apr 01, 2014 | HP Officejet 6500A Plus Wireless...
I want to stop my philips magic 5 "replace inkflim from flashing. I'm not able to access my messages or send faxes. I dont have a replacement inkfilm. Thanks
the fax hackers are still researching the method to disable plug-n-print chipcard in magic 5 series. magic 3 series has been solved in hidden service menu.
This means you need to buy a new inkfilm with new chipcard included. sorry.
Apr 04, 2011 | Philips PPF-531 Plain Paper Thermal...
BT Magic Box How do I change the ring tone?
hi,
go to profile.
go to personalize.
go to ringing tone and change the ringing tone to the one you want.
thanks for using fixya.
May 29, 2010 | Lands Phones
Instructions how to use a philips magic 5 eco fax machine
You can try this link to download your owners manual, but you;ll have to rate the fax machine first. Just click the stars, then click on, Download.
Download the complete
user guide (6024 Ko)
Feb 02, 2010 | Philips Lands Phones
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
I bought your digital cordless phones two weeks ago and now we recieve no incoming calls because they do not ring although we know that they are ringing also we cannot ring out we hear the number being...
They're not mine or FixYa's phones, they are yours.
Are you hearing dial tone before you ring out? When a phone doesn't dial or ring, it's the first sign that it's not connected to a working phone line. Try a regular phone in the same jack first.
Carl
Dec 13, 2009 | Philips Lands Phones
Phillips magic 5 voice dect fax
phillips magic 5 dect fax showing ''1 pending error''
cant remov e it
Nov 16, 2009 | Philips Office Equipment & Supplies
Philips magic 5 classic
You need to set the machine to receive faxes manually. In my instruction book it's on page 14.
Jan 15, 2008 | Philips Magic3Voice PPF585 Printer
Philips Magic5 Voice DECT Duo - Fax / copier - thermal transfer - 50 sheets - 14.4 Kbps Plain Paper Logo
102 people viewed this question
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
