Question about HP Office Equipment & Supplies
My Black ink suddenly started to run out when the cartridge is full. I changed the cartridge and it is still doing the same thing. I have an officejet Hp6500
    Master:
  • 354 Answers
Well the head is bad or the contacts need cleaned ,The head is what jets the ink out of the cartridge so it is either bad or not making good contact with the cartidge. Clean contacts with rubbing alcohol and a Q-tip and hope its the contacts cause those heads are expensive.
Posted on Apr 01, 2011
Black ink cartridge is full, when printing no black showing
Reset waste ink counter
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
Start with printer on then run this software
Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Or
When you insert a refilled ink cartridge into your Pixma MP500 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won't get the warnings again because the ink levels won't be monitored by the printer.
Feb 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
The black ink cannot be
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed? Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred? Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If not, do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then there are other things we can try - assuming other solutions haven't worked either. Report back on my queries etc.
Feb 10, 2009 | Epson Stylus C43SX InkJet Printer
My Pixma stopped printing black.
Have you installed the full software that came with the printer? If so then it would tell you if the black ink had run out.
Start by replacing the ink cartridge. If you can replace the black only then do so, if not then replace the cartridge that contains black (along with the other colors).
It is quite common for the black to run out 1st, which is why many printers feature a separate black cartridge.
If that does not help then get back to me and we can look at some other alternatives.
Oct 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
I have an HP Photosmart Printer D6160 which I have been using very successfully. It suddenly will not print black but all colours are OK. It shows black cartridge is half full. Have cleaned heads,...
sometimes the pipes get clogged and you might have to do a clean repeatedly i.e. 5 or 6 times, to get the ink flowing again. the only probelm with this is that it is very heavy on ink usage for the other cartridges as well! Alternatively the printer might be faulty so if it is in warranty ring HPs suport line and get it swapped.
May 10, 2008 | Office Equipment & Supplies
Ink cartridge problems
exchanged the black cartridge (57): the printer told me there was a problem with it, that I should remove it and re-insert it. I did, the ink button still blicks. After several efforts the printer started to work again, printed one document and then told me there was a problem with the colour cartridge. I removed it, re-inserted it several times. Finally a test page was printed - everything was okay.
Then the printer refused to print anything - the yellow LED lamp blicks continuously. Have turned the printer on and off, have also shut down the computer and re-started.
The only thing that will work now is the black cartridge, if I remove the colour one.
May 08, 2008 | Canon PIXMA MP530 All-In-One InkJet...
PRINTING PROBLEM
You printer cartridges need to be cleaned,aligned properly...printer software can do that...
PLEASE RATE ME AS ( FIXYA ) <blue boxes>............
Oct 19, 2007 | Epson Stylus D88 InkJet Photo Printer
Won't print in black
open your list of printers. r/click on the 780 and open properties. fo to the last tab "maintenance" and run cleaning 2 or 3 times then run deep cleaning 2 or 3 times. and see how this helps. If you've never done it before you might want to take out the print head and clean it with alcohol. Take out all the ink like you were changing them then reach in and gently pull out the container that holds the ink. This is the print head. Clean it and replace it, then run clean and deep clean again. run Nozzle check to see how clean it's become and you'll definetly see a difference in your printing. good luck
Sep 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
