Question about Canon Pixma iP6600D InkJet Photo Printer
Error code 6500 came up to my ip6600d. I would appreciate any assistance.
  • Brian Manuel Apr 01, 2011
    Don't know model but what is it or isn't it doing?
How do I fix a Canon pixma ip6600D printer?
ALARM LIGHT which always glows - RAM error (logic board is dead)
Apr 02, 2015 | Canon Pixma iP6600D InkJet Photo Printer
How do I fix error code 6500 on my Canon Pixma?
You should have at the bottom of the print page a error code touch it and it will tell you what that code means and steps to correct it. It's either had a jam or out of ink or paper. If all else fails unplug and restart.
Feb 11, 2015 | Canon Pixma iP6600D InkJet Photo Printer
How do I fiux \ how do I fix error code 6500 canon pixma iP6600D
6500 Other hardware error often this means
logic board or ac/dc adapter is not working properly or dead
Pixma ip660d displays 6500 error code
Hello
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Feb 17, 2011 | Canon Pixma iP6600D InkJet Photo Printer
Error code 6500
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you better ask for replacement.
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much a user can do except replacing the malfunctioning hardware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6500
Issue: ERROR: Error code 6500
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request
If the above does not help:
Solution: The MP500 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
Find a Service Location
Nov 11, 2010 | Canon Pixma MP500 All-In-One InkJet...
Code Required for Visteon 6500 Europe -------------------------------------------------------------------------------- Hi please could someone help me out I am trying to obtain a Key code for my Landrover...
Go to carhelpsite.com it is free as long as you click on 2 of the ads at the website then your questions will be answered by an ASE certified mechanic,you don't have to buy or fill out anything on the ads,so help keep the site free.
Apr 14, 2010 | 2003 Land Rover Freelander
Pixma ip6600D I am getting Error code 6A00 can it
You need a new purge assembly, I do those here in the shop for around $112.00 total, part, labor and tax.
Dec 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Screen shows error code 6500
4. Properly seated
Good Luck!!
Thanks
Sep 09, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Error code 6500
This is caused by the information in your registry. Please refer to the following link and download the Advanced Windows Care ... you will not be disappointed ... Scan with AWC and try your printer again. The message displayed is an error, I am supposing.
http://www.iobit.com/advancedwindowscareper.html
Terry
May 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
159 people viewed this question
old marine
old marine
