Question about Kitchen Ranges
What is the other replacement of R2M diode? - Kitchen Ranges
4 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: dead set ; fuse ,
You need to confirm where is the trouble before replacing any parts.
Test the B+ on the H-out transistor.
No-check the B+ on 160v electrolytic cap.
If No B+ here then the trouble is in the regulator section before the chopper if it has.
Let me know the reading from your ohmmeter.
Thanks for using Fixya.
JDVillanueva
Posted on Feb 03, 2011
gopakumarg43
  • 75169 Answers
SOURCE: Thanks, this tv burn the diode r2m after 10 or 15 minutes in this lapse the tv works normal
Hello
Check the power supply switching regulator board [SMPS] for over output voltage that it meant to be.
Posted on Mar 06, 2012
gopakumarg43
  • 75169 Answers
SOURCE: do you know R2m diode ?so diode is support other number?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Feb 25, 2016
Sony kv2187 r2m zd burns every time
Please explain with a diagramme if you can.
May 08, 2016 | Sony Computers & Internet
Tip
How to replace a microwave oven's diode:
Replacing a high voltage diode<br /><br />The first thing you must do to replace your microwave's diode is unplug the unit from the wall outlet.<br /><br />Next you will have to discharge the high voltage capacitor. A capacitor stores large amounts of electricity even when the unit is unplugged. It is necessary to discharge the high voltage capacitor in order to avoid receiving an electrical shock.<br /><br />Diode replacement is relatively straightforward because most high voltage diodes have a press fit, also known as Fast-On, or they have ring lugs. If your replacement diode can be installed either way, make sure you get the right polarity. Remember that a diode will conduct an electrical current when a forward voltage is applied, but when a reverse voltage is applied, there is no conduction.<br /><br />Remove the diode from your microwave and replace it with the new one. You may be able to crimp the new diode onto the wire leads, without welding or soldering them together. If you do crimp the diode onto the leads, be sure not to apply too much pressure, as this may cause connection problems either now or in the future. <br /><br />I hope this is helpful.<br />
on Dec 02, 2010 | Microwave Ovens
Do you know R2m diode ?so diode is support other number?
Feb 24, 2016 | Televison & Video
How to fix a diode on a 94 nissan maxima
When replacing a diode always follow its polarity,You have anode and a cathode. on one end of the diode,the purpose of the diode is to limit the voltage.If you are replaceing the diode in the alternator it is shape one way,just unsolder it
Mar 13, 2012 | Cars & Trucks
Hello
Mar 05, 2012 | Daewoo DTQ-20V1FS 20" TV
Dead set ; fuse , ic regulator , horizontal output transistor , r2m diode replaced already. Still dead set.
JDVillanueva
Feb 03, 2011 | Televison & Video
Panasonic TC-21S10M2 TV
R2M diode is 130v zener, the missing diode is RM25 which is 55V zener for over voltage protection.
May 05, 2009 | Panasonic Televison & Video
RCA P52921yx2 WIll not power on only clicks
try to check the h-transistor and test it with 360tr multi tester and if not deffective try to also check the r2m zener diode
Nov 29, 2007 | RCA P52921 52" Rear Projection Television
Neff combi blown diode.
If the diode failed by opening, there may be no other damage. If the dioded failed by shorting, the alternating current may have damaged other components. Ohm it out. You can get diodes from digikey.com, mouser.com, or radio shack or any electronics or appliance supply. If the diode is charred and you can't get the part number, the oven rating can be used to select a replacement. Since the fuse was 10 amps, the diode should also handle at least 10 amps. If you can power the unit and read the voltage at the diode input this will give you the power (volts times amps). It's always worth trying as it's cheaper than replacing the unit.
Oct 14, 2007 | Neff H7871N2GB Convection / Microwave Oven
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
