Question about LG Dishwashers
The water is not coming into the dishwasher. The valve is open. What could the problem be?
  • 822 Answers
You have a valve in the machinr............
follow the inlet hose which connects to the machine valve....
this may be sticking.......
cheers
Posted on Apr 01, 2011
  • jennyjck Apr 01, 2011
    Thanks for that!
  • paul
    paul Apr 01, 2011
    no probs................cheers
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Dishwasher is giving E1 which according to the manual is water sorce is off. We recently had turned the water off for bathroom repairs but the water has been turned back on, we have disconnected the pipes...
This is common, there may be a flood protection device that tripped in the line or sediment got into the system when the water was turned back on.
First turn the water off to the dishwasher. Take the hose or pipe off at the connection under the dishwasher, put a pan or towels under that open pipe. Slowly turn the water on and flush that line until clear. If no water comes out then you will need to do this but further back 'upstream'.
Once water comes clear, turn the valve off again reconnect the pipe/hose to the dishwasher and very slowly open the valve. If the water does not enter now you have sediment in the water inlet valve on the dishwasher itself and that valve will need replaced.
Jul 30, 2010 | Maytag Dishwashers
Dishwasher problems
the first thought that comes to mind is the valve... are you sure the water valve to the dishwasher is open?
The next possible cause could be a bad relay switch which opens when the unit calls for water... if it's bad the switch will stay closed and it won't fill up
Sometimes when the unit is brand new it may take several tries before it starts pumping water thru because the line needs to purge.
could also be a severe kink in the water supply line from the valve...
Sep 04, 2009 | Bosch 23 in. SHU33A Built-In Dishwasher
We lost electricity very briefly today which caused the dishwasher, washing, drying, clean buttons to blink when the electricity came back on. I opened the door to do a load of dishes hours after the...
it seems unit fill valve is stuck open and water is coming in even when machine is off.fill valve opens up only when u start the unit.2 chks this u can open the door and look at the hole inside from where water comes in.if water is coming in with dooe open then 4 sure valve is bad and needs 2 be replaced.
Aug 11, 2009 | Frigidaire 24 in. PLD2850 Built-in...
I have a GE GSD2230Z00WW dishwasher water will not fill on start no power on the fill valve either. Water will come on quick wash cycle and rinse.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
***If everything checks out ok with the water inlet valve, replace the timer or control board.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
No water is coming to dishwasher
Check and see if you have 120 comming to the fill valve. if you do the start to loosen the hose you connected to make sure the valve actually opened when you turned the water back on
Nov 25, 2008 | Maytag 24 in. MDB4651A Built-in Dishwasher
Frigidaire 18" dishwasher
Check the electrical water inlet valve for sand or unwanted partical on the valve. If the valve can not be open and clean, change the valve.
Nov 16, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
43 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
