Question about Kenwood SB206 Smoothie Pro 3Speed Blender
Hi, I have a glass blender that came with my Kenwood FP950 food processor. I am trying to clean the base of the blender by removing the glass jar from the blade unit, but can't remove the base. Could you please advise? Thanks!
How to remove splash guard from base
Good evening
it is difficult to take the bottom things from each other. The blenders I know are screwed to each other,
all the best
kolbrun
Feb 01, 2015 | Euro-Pro Ninja Master Prep Blender and...
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Krups blender switch lights, but motor doesn't turn
Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
kolbrun
Mar 14, 2014 | Krups KB790 Blender
Starbucks Glass jar replacement for blender
I bought an Oster 6 cup glass and it works perfectly on the Starbucks Barista blender. It has to be the 6 cup NOT the 5 cup or the blade mechanism won't fit. the 6 cup screws right on your old blade base and it was $10 new on Ebay including free shipping.
Feb 20, 2014 | Braun MX2050 Blender Powermax Replacement...
Leaks from the bottom of the glass jar. Bought a new gasket and it is worse than ever.
Are you sure you are installing the gasket correctly?
Leaks are usually the result of a misaligned or cross-threaded blender jar base or from the gasket being installed incorrectly. Make sure the gasket is installed between the blade assembly and the screw on base.
If this does not help, please reply or repost.
Dec 07, 2012 | KitchenAid 5-speed Blender With Glass...
Can not remove base from blender model BL5500SC
leave the blender jar on the blender. with one hand grab the glass jar handle with the other hand hold the base of the blender. then twist or push the handle counterclockwise to free it up so you can completely remove it from the blade
May 19, 2012 | Blenders
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
Blender does not blend, only buzzes. So I took the blender jar off the motor base and tried running it. It ran just fine. Put the jar back on the base and it only buzzed. Figured a piece of frozen fruit...
Smart move. The blade assembly is almost frozen and the motor does not have enough torque.. You need to remove the blade assembly and completely clean out the bearing and reassemble after the Mr. clean operation. A lite dab of oil is also called for.
Sep 10, 2017 | Oster 006832000000 10Speed Blender
Blender seems to run right until you put glass jar on.runs very slow.
Disassemble the base from the jar, and check the placement of the gasket. Reassembly, with the jar upside down is gasket, blades, then base. While disassembled, rotate the blades by hand just to make sure that they aren't in a bind. Replace if defective.
--W/D--
Mar 06, 2011 | Hamilton Beach 50754 WaveStation 10 Speed...
The plastic threaded base for the jar on this blender haier 2 speed / glass jar is cracked - is part available ? thanks
The base ring part probably is available, however, you MIGHT want to try gluing it with the BLACK ABS plumbing glue. It is surprizingly strong if you have clean break
Sep 16, 2009 | Haier HB500 2-Speed Blender
Kenwood SB206 Smoothie Pro 3Speed Blender Logo
156 people viewed this question
Top Kenwood Blenders Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Kenwood Blender Expert? Answer questions, earn points and help others
