Question about Olympus Ds71 (4096 MB 10625 Hours) Handheld Digital Voice Recorder
My WS-750 M froze and I was forced to remove the battery to stop it. After I reinserted the battery it did not start any more. I am using it now as a paperweight... Juan
    Top Expert:
  • Olympus Master
  • 74,383 Answers
Hello
If nothing appaears on its display, check the batteries; whether they are not loaded properly,[verify the polarity of batteries inserted]; are batteries are dead or Power ON switch is off.
After replacing the batteries, time set is necessary.
Check whether the abtteries are inserted properly first. If you have its user manual, the method is pictureised in it. Refer to it. If there is no display at all, and the batteries and in good condition, inserted properly according to polarity, and the power switch at its side is ON; the unit has been damaged. Check the contacts springs of battery contacts are rusty or dirty, clean it well first, and insert the batteries. If you haven't its user manual, send your email address to me by Fixya; I'll sedn the manual to you by return mail. OK.
Posted on Apr 01, 2011
I have a 2005 brute force 750 won't start with electric start it will start when I pull start it will run.when it's running the lites and display are flickering .
Sounds like your battery is about dead... replace the battery and clean the connectors/wires/terminals.. and a little waterproof grease will stop the corrosion. Make sure the new connections are tight!
Jan 25, 2017 | kawasaki 2005 Brute Force 750 4x4i
Hit the start button and nothing happens 2008 750 brute force
Check your starter solenoid. You can trace it by following the power wire from the battery to the small solenoid block that contains a 30 amp fuse. You can bridge the posts on the solenoid by using needle nose pliers or whatever else you may have. If it starts up or you hear the starter run, you have a bad starter solenoid.
Feb 02, 2016 | kawasaki 2008 Brute Force 750 NRA OUTDOORS
05 kawasaki bf 750...battery was low......put a new one in..........now backfires out the exhaust.......tried the belt reset.....didnt help......suggestions.?.....
Brute force backfire problem - YouTube
? 1:06
www.youtube.com/watch?v=VFxGBYoVFqk
May 5, 2013 - Uploaded by gubba1957
I bought this 2006 750 it had a backfire problem when I bought it so I cleaned ... 2005 Kawasaki Brute Force 750 - Stock Exhaust Modification ...
Oct 03, 2015 | kawasaki 2005 Brute Force 750 4x4i
Asus tp500L. Purchased new laptop 360degree flip using it for uni assignment but froze so I forced shutdown but now can't turn it back on? Please help
Try to
-remove the battery and power plug
-press and hold the start button for 30 seconds
-put the battery back -start on the battery or power cord
Nov 15, 2014 | Computers & Internet
Frozen camera
And after removing the battery, you first charged the battery before reinserting it?
Because when a camera suddenly stops, most of the time the battery is empty. At least it does not have enough power to work safely.
Try charging the battery, and reinsert it. Then I hope everything will look different.
Still it could be the battery is not in working order, but you should notice a different behaviour when charging it. If it almost takes as long as normal to charge the battery it should be ok.
Feb 09, 2014 | Nikon Coolpix S3300
Keyboard frozen
try to turn off the laptop then remove the cables and battery. Then press and hold the power button for 8 secs. Reinsert the cables and battery and then turn on the laptop. Check if the keyboard is still froze. If it is so, try to remove unnecessary files on the computer by clicking Start > All Programs > Accessories > System Tools > Disc Cleanup. In doing so, you will remove not so important files on your laptop so that it would run better. Otherwise if the keyboard is still stuck, try to call HP to repair it..
Feb 02, 2011 | HP Pavilion dv9000z Notebook
Froze up, turned off and turned back on. all that happens is the motorola symbol and thats it
Remove the battery with unit off. then reinsert the battery and attempt to reboot it(turn it on)
Nov 26, 2009 | Motorola Mobility Hint QA30 Cell Phone
Excess travel on front brakes of a gsxr 750 ws
You need to make sure master cyl clean possibly needs new seals or master cyl,but try this remove pads keep pumping cyl so that pistons come out further place some wood or plastic between disc and pistons thinner than your pads that should stop your pistons coming out and will allow more fluid into the caliper,then press the pistons back to return fluid back up pipe to pressurise valve good luck it may not work first time just keep pumping .
Apr 25, 2009 | 1995 Suzuki GSX-R 750 WS
Olympus Ds71 (4096 MB 10625 Hours) Handheld Digital Voice Recorder Logo
48 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
