Question about HP OfficeJet 7410 All-In-One InkJet Printer
Problem with scanning both from the auto feeder and from scanner glass
When ever I tried to scan a document into the computer from my hp 7410 scanner glass and / or automatic feeder, I always get an error message that says " Original were removed from the input tray of the automatic feed. Please replace the originals and click New scan. To scan from the scanner glass instead, make sure that all items are removed from the automatic feeder. Then close the HP scanning software and start again. Ok "
The above statement shows up, even when document is on the automatic glass. I tried scanning 8 pages of document into the computer through the automatic feeder, the pages began scaning and the number of documents scanned increased with each page scanned page up until after the 8 page, when the scanner tried to scan the 9th page that was not there, there was also a grinding noise, after which the above error message occured. I have checked to see if there is any paper jammed in automatic feeder but none was seen after lifting the auto feeder cover.
What could be happening and what can be done to get documents to scan. I will appreciate any solution to this.
Thanks,
Emmanuel
  • ikcon1 Aug 05, 2008
    Nothing was replaced or fixed in the printer. Any further solutions.
    I am still looking for solution regarding this scanner. Nothing was replaced or fixed on this pringer.
    Master:
  • 623 Answers
Check the rail gears worn out needs replacing
Posted on Aug 05, 2008
  • 659 Answers
This is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (Problem with scanning both from the auto feeder an - c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
    Press the power button (c00636182.gif ) to turn off the product.
  1. Disconnect the USB cable from the product.
  2. Unplug the power cord from the wall outlet and from the back of the product.
  3. Wait a couple of minutes to allow static to be discharged.
  4. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  5. Connect the product to a different UProblem with scanning both from the auto feeder an - c00636182.gif class="h_mi"> Turn on the computer.
  6. Press the power button (c00636182.gif ) to turn on the product.
  7. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams cProblem with scanning both from the auto feeder an - c00636182.gife internal components of the product from moving, which can create unusual noises.
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the frontProblem with scanning both from the auto feeder an - c00636182.gifct.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Problem with scanning both from the auto feeder an - c00636182.gif. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    • 1 more comment
    • Wesley Gardner
      Wesley Gardner Aug 05, 2008
      1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
      2. Close the product cover and reconnect the power cord.
      3. Press the power button ( ) to turn on the product.
      4. If the noise persists, proceed to the next step.
      5. Step six: Plug the product into a wall outlet
      If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
      1. Unplug the power cord from any power strips or surge protectors.
      2. Plug the power cord directly into a wall outlet instead.
      3. Press the power button ( ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
      Step eight: Service the product
      If you have completed all the steps listed above and are still experiencing a problem, service the product.
    • Wesley Gardner
      and if you contact HP they will guide you through the steps listed thats their troubleshooting method.
    • Wesley Gardner
      i think the noise has more to do with it then anything.
      but if you wanna try updating the software and drivers click here
      but your best bet would be to follow that guide and then contact hp regarding the noise.
      Also you machine if needs a cleaning view this
    • 3,037 Answers
    Sounds like a sensor issue with the unit. Basically you will need to find the sensor, try cleaning it and if that doesn't work, see if you can order a replacement. Let me know of anything that you may need help with
    my best to you
    • HP Master
    • 6,487 Answers
    If only the scanning function of it is not working fine, you can first try updating the driver for the scanner , because base what you have stated it scan some document but not all.
    Hope that helps......
      Guru:
    • 1,894 Answers
    Have you replaced or repaired any part of the printer recently?
    this does not seem like a paper jam.. problem is somewhere else..
    2 Suggested Answers
    • 1894 Answers
    SOURCE: Problem with scanning both from the auto feeder and from scanner glass
    this is what HP has to say
    2. Disconnect the USB cable from the product.
    3. Unplug the power cord from the wall outlet and from the back of the product.
    4. Wait a couple of minutes to allow static to be discharged.
    5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
    6. Connect the product to a different USB port.
    7. Turn on the computer.
    8. Press the power button (c00636182.gif ) to turn on the product.
    9. If the noise persists, service the product.
    Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Cannot scan legal size document with windows 7
    Of course it can't . Since the maximum scan size is 8.5 x 11.7 inches it cannot scan a document that is 8.5 x 14 inches which is legal size. To do legal size you must either have a large-format scanner so the glass size is large enough, or have an all-in-one that has an auto-feeder. Those use a different scan bar from the feeder and can do legal documents.
    Mar 21, 2015 | HP Deskjet 3050 Multifunction Printer
    I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
    Follow these steps to scan using HP software:Step one: Load the item to be scanned
    1. Make sure that the product is connected to the computer.
    2. Turn on the product.
    3. Load the item in the document feeder tray or on the scanner glass
    Tip
    Load the following items in the document feeder tray :
    • Single items
    • Items that are not easily damaged
    • Multipage, single sided items that you want to scan into one file
    Load the following items on the scanner glass :
    • Single items
    • Items that are easily damaged, such as old documents and photos
    • Multipage, double sided items that you want to scan into one file
    • Option one: Document feeder tray
      1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
      2. Adjust the width guides to fit the item.
    • Option two: Scanner glass
      1. Open the scanner lid.
      2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
      3. Close the scanner lid.
    Step two: Scan the item Use one of the following methods to open the HP scan window:
    • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
    • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
    Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
    Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
    Save as JPEG Use this setting to scan pictures and images.
    Hope this information will be helpful.
    Let me know.
    Regard
    Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
    When I scan to printer the page comes out with short lines down 1 side
    If your printer has both an automatic document feeder and a flat glass portion for scanning, try scanning from both. If you only get the lines on one of the scans then that is where your problem is. Most common issue on scanners is a liquid paper, bit of paper, glue, etc on the Automatic document feeder glass. Clean the glass and you should be fine.
    Apr 02, 2011 | HP Office Equipment & Supplies
    Every time I scan lines appears either on document or pictures. I tried cleaning the glass but nothing happens.
    Clean the **** glass with alcohol. The **** glass is the little glass that paper is scanned over when using a automatic document feeder.
    Jun 18, 2010 | HP 5590 ScanJet Flatbed Scanner
    How do i use my scanner
    If you have loaded the software for the printer/scanner.
    Go to your HP director Icon and start this program.
    you should see your Scanner / printer listed under Select device.
    You can place a document/picture in the document feeder on top.
    OR you can place the document / picture directly on the glass.
    (Lift the hinged lid to reveal the scanner glass)
    Don't worry the document feeder uses a different scan wand.
    Now document / picture in place select the Scan document or Scan picture icon from the HP director. Depending on which type of document you have placed in / on the scanner.
    Scanner should warm up then scan presenting you with a preview image. From here you can decide what and where to go.
    You are not limited to just the HP director.
    Other applications can use the twain source to activate your scanner software. This will transfer the scan to your application.
    Irfanview is a prime example. Image viewer that will let you "Acquire" and image from you scanner. Be sure to select the twain source.
    Nov 10, 2009 | HP OfficeJet J4580 All-In-One Laser...
    Red/yellow line down left side of document when using feeder
    the solution to this issue is cleaning the scanner glass below the automatic document feeder(mind you its not the scan bed that you normally use while copying) .you will get the ADF scnner glass once you lift the ADF door,you will see a 1 inch wide scanner glass.that is what you need to clean.
    If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
    Jun 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    HP 7410 streaks when using auto document feeder to make copies
    the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
    Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Good, so u are having probs in ADF. Open the cover, lift the rollers and u can see the scanning glass. Take a lint free cloth and clean it. it will be ok.
    Feb 03, 2008 | HP OfficeJet 7410 All-In-One InkJet...
    HP 7410 streaks on scanning and copying
    First you need to determine if it's doing from both the  top and the glass.
    1-assuming you are using the feeder to fax,copy or scan (the part that automatically picks up the paper) it comes out with a streak. Make a copy putting the paper on the glass and look at the copy. Does it have the streak?
    2-lift the top and look to the left there should be a small 1inch glass, this is where it makes the copies from the feeder, is there a dot or white out or is the glass dirty? that's your streak, the paper is moving to make the copy,so the dot now looks like a line as opposed to making a copy on the glass it just sits there so a dot will stay a dot.
    2- Clean with water or alcohol.
    Oct 23, 2007 | HP OfficeJet 7410 All-In-One InkJet...
    HP OfficeJet 7410 All-In-One InkJet Printer Logo
    284 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
