Question about Samsung Office Equipment & Supplies
I cannot reinstall my samsung scx 4521f printer driver - error message says cannot create a new file - it already exists I have tried deleting the old driver a number of times. I have also rebooted the computer after each deletion and after each reinstallation
  • 2 more comments
  • Bharat Patel Apr 01, 2011
    Thank you Caroldob .
    However - I made four attempts at removing the driver by doing exactly as you suggested. However The icon continued to show up after each attempt , UNTIL the last attempt , when it stopped showing up.
    BUT even then, after another attempt at at reinstalling , the error message re-appeared.
    Thank you again caroldon - Now this one is worth a try.
    I will make an attempt tomorrow sometime - It is getting rather late tonight.
    I do appreciate this.
    I will let you know
  • Bharat Patel Apr 06, 2011
    Hi again Caroldon
    Fixed it at last.
    Apparently my Print spooler was causing the problem - A freind got me to downlad a spoll cleaner from the Microsoft website , and clean the Print spooler by using the software, going through Command prompt and typing in 'Cleansplr'
    BUT you have been very helpful - Thank you
    very helpful - tank you
  • Samsung Master
  • 17,130 Answers
It is possible that the OS is corrupt in your PC as the old driver of the printer is not being UNINSTALLED.
Just to make this clear the drivers of the printer MUST BE UNINSTALLED by opening programs- add/remove , click on the printer driver ICON and it will ask to proceed for un-installation.
This must be done and the driver will be UNINSTALLED.
Now BEFORE this is done the printer MUST be removed from the PC.
Once the driver is removed reinstall the driver software into the PC and after a successful installation CONNECT the printer as it will be detected as a NEW HARDWARE AND INSTALLED.
This must be the sequence if you have not done as above repeat.
if not the OS and drivers must be reinstalled as there are errors.
Posted on Apr 01, 2011
  • Donald DCruz
    Donald DCruz Apr 01, 2011
    Seems you have done the right way but without sucess as there are errors in the PC.
    Since othere systems do have access this can be a reason.
    Hope the printer drivers are good , if not get another fresh download .
  • Donald DCruz
    Hope it works and I could help. Thanks
Samsung scx-4521f fax memory received but never print out
Reinstall the driver of your samsung scx-4521f.This thing happened to me and my solution fix the problem.
Goodluck !
Sep 14, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Keep getting error message after installing SmarThru: "installation of smarThru is not completed. you need to reboot..." but rebooting doesn't help - why?
your computer is asking for the reboot to delete some files cuz the installation failed so it will never working that way try the manual installation if you can dont use the auto-run disc
rather when it tells new hardware found click on it choose manually then select the files according to printer model
May 23, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Samsung multifunction printer fails due to update
you may try to uninstall & reinstall the driver from samsung website. www.samsung.com
this might help
Apr 27, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Setup
Go to Control panel>>Installed printers and delete your samsung from installed printer list.
After deleting, unplug printer cable, restart computer and reinstall the software from disk.
If you do not have disk you can download software and manual from here: download center SAMSUNG
Feb 14, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Problem scanning with samsung scx 4521f
Sorry to have missed your initial posting...
In any case, to my understanding, this particular printer is likewise capable of USB connection. Perhaps you can try connecting it pure USB and go through the installation again. this might simplify interface and communications between notebook and scanner/printer.
If for some reason you would want to retain Printer/Parallel to Notebook/USB, you need to check your Imaging Devices in the notebook's Device Manager and verify that all drivers are installed for the Samsung SCX-4521F. There should be no yellow or red marks. If there are or if the Samsung SCX-4521F instance is not present, you may need to reinstall using the Add Hardware Option in the Control Panel. You may need to manually select the imaging device/scanner. This holds true if you are using Windows XP.
If you are using Vista, you may need to download all the Vista drivers from the Samsung website. Further, pls be informed that to my knowledge, Vista has certain issues with USB ports. Microsoft has issued a patch/update specifically for this concern. It may be downloaded from here or here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Samsung SCX 4521F All-In-One Laser Printer
94 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
