Question about Emerson Fans Emerson WM320 Wireless Microphone Dual Channel DVD Karaoke Converter w30Song DVD
I lost my owners manual to my emerson WM320 karaoke. I need to know how to connect it to my tv
I need owner manual for Disney HM950KC karaoke machine
i am trying to connect this to my stereo, the volume is not loud enough, so i bought a split cable, connected to one of my outputs on my stereo receiver. it works but very deep, so i bought a thicker split cable and will try, but not sure how to hook up the video part. a staight wire to the back of my tv? will that work? also i cant find the right kareoke videos, each time I buy one, computer graphics come up but no words, any direction, send to ldeleon@reddyraw.com please
Sep 30, 2012 | Disney Hannah Montana Karaoke System with...
GPX Karaoke Machine with AM/FM radio and cassette, Manufactured 1/2001 Model C1550 do not know how to hook up to TV/VCR ?
On the rear of the unit, the RCA jack on the lower left corner of the jack panel should be yellow and marked Video out. take a RCA to RCA plug into the video out on the unit, then plug the other end into Video in on the TV.
I'll attempt to send you the manual thru the link below:
http://www.gpx.com/owners_manuals/JM250S-IB.pdf
Good Luck, and don't forget to rate the answer. Let me know if this doesn't help.
M
Sep 21, 2011 | Digital Products International Karaoke...
Plug broke..can it be fixed by splicing a new plug on it? If so how do we do it? Also lost instructions on how to use are these available?
I can't really guess what plug you are refering to since there are more than one... Power? Microphone? Any competent electronic person that can solder wires can repair this. If cables break for instance at microphones one may have to crack open the shell to shorten the cable a bit and resolder a couple wires and glue it back together... If the plug at the end of a cable is broken, get part at a Radio Shack...
Apr 30, 2011 | Emerson Fans Dual Plug N Sing Handheld...
I picked up a vocopro karaoke machine at a yard sale and the echo makes a loud hum also i need a owners manual and remote where can i get help with this. model#890G thank you
Hello. For the manual and remote your best option is to search online. As far as the echo goes, this is just a cheap microphone with a cheap system. It will not go away unless you turn the volume down on the system. If you want to put good money down on a nice SHURE brand microphone it will definitly help with the echo, however it will not make the system any better.
Apr 17, 2011 | Vocopro DVD-Duet Multi-Format Karaoke...
How to turn off vocal on Emerson GM527 so that we can only hear the music and sing along.
Note that you MUST use the special Karaoke disks to be able to remove the vocal... it will not do it for plain music CD's. Those devices that CLAIM to remove vocals often do so poorly... they do it by subtracting the left and right channels which ASSUMES the lead vocal is centered between the channels... Those methods don't work very well...
Jan 12, 2011 | Emerson Fans GM527 Karaoke Player w 7 LCD...
Emerson Fans Emerson WM320 Wireless Microphone Dual Channel DVD Karaoke Converter w30Song DVD Logo
Top Emerson Fans Music Experts
Michial Gueffroy
Are you an Emerson Fans Music Expert? Answer questions, earn points and help others
