Question about Hitachi Televison & Video
My tv screen goes out then comes back on. What could be causing this?
  • judycruz Apr 01, 2011
    Thank you I will try that
    President:
  • 1,654 Answers
Most likely the lamp is going bad, overheating, or the lamp ballast is weak. I bet on the ballast or the overheating. Put a fan near the rear of the set and blow some air into the back and see if this helps. If not then it will need a tech to diagnose the issue
Posted on Apr 01, 2011
My Viore flat panel tv comes on for a few moments, then the lamp and temp/standby light flashes and the screen goes dark. The picture is just fine for the first few moments, and then it goes dark. Any
this is caused by a bad connection, or a faulty back light. It is also something you should have a local repair man have do for you if you are not "tech savvy".
Sep 23, 2014 | Televison & Video
My 50hm67 turns on for a bit then turns off or lose screen for a bit then turns back on
Some simple things to be aware of: A lamp (generic cheap) or one reaching the end of its life can cause this issue, what is age and brand of lamp in the set?
Nov 02, 2012 | Toshiba 50HM67 50" HDTV
My TV comes on with vertical lines rolling up on the screen with picture. The picture also freezes and then goes to the blue screen for a while and then comes back on perfect. Is there a problem with the...
No,the T-CON board it is dying and the causes to causes this problems.That the board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Aug 03, 2011 | Westinghouse LTV-20V2SL 20.1 in. ED-Ready...
Iv had an n64 before so i think i have a good idea of how to set it up. i've managed to tune my tv in to find where abouts it is but there's only a black screen.i can turn the n64 off an the tv screen goes...
Adjust the vertical or horizontal hold controls. This is helpful even if regular TV stations come in fine. If your TV has an automatic fine tuning control (called AFC or AFT), turn it OFF. Use the manual fine tuning dial to adjust the picture. If turning OFF the AFC/AFT causes your TV to display in black and white, then leave the AFC/AFT ON. Slide the Power Switch on the Control Deck to the ON position. While the control deck remains ON, turn the TV off for 10 second then back on again. This resets your AFC/AFT so that it will tune in the signal from the control deck.
Move your control deck farther away from your TV. If the control deck is too close to the TV, the control deck may cause some interference.
Jan 19, 2011 | Nintendo 64 Console
When watching tv on any mode...after a few seconds screen goes dark and sound goes out...then a few seconds later it all comes back...happends repeatly...any thoughts?
Time to replace Lamp in TV.
Existing lamp getting weak and causing that problem, replace lamp and TV will be fixed.
Buy Sony original lamp for TV safety and lamp replacement procedure is written in user manual.
Thanks.
Jan 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue screen
Could be something to do with your channels not tuned in propperly or your signal is being lost.
Sep 30, 2008 | Sony KP-57WS520 57" Rear Projection...
Screen goes black immediately after astar logo screen comes on
Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Jan 21, 2008 | Astar LTV-3001 TV
Televison & Video Logo
130 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
