Question about Saitek Cyborg X Joystick
The trigger and it's spring broke off and I don't know how to fix it, can you help me?
My NERF gun broke.
Take it back to where you bought it. It shouldnt do that, it sounds faulty to me. I am sure they will replace a faulty item.
Feb 26, 2014 | Hasbro Nerf N-strike Longstrike Cs-6 2010...
I am trying to put a throttle trigger on my weed eater it's a stihl fs55c I can't figure out where the spring goes its been broke awhile I took it apart but I can't remember how it goes I...
with the trimmer engine to your left and the shaft to your right the trigger spring goes on the peg that holds it in the body like an L. It is going to be difficult to explain exactly how to do it and the pics I get from my phone are way to large to post here even after changing the resolution
Mar 30, 2013 | Garden
Trigger don't release
I have a hose and gun that fits the McCulloch FHH18A that I no longer need as I had to buy a complete universal hose/gun and wand unit since I had broke the wand and the replacement wand was no longer available. If you are interested in it, email me at burmakow@nwciowa.edu and we can figure out a price.
Apr 28, 2012 | McCulloch FHH18A Electric Pressure Washer
The clutch peteal is not geting presure behind it and don t know y
mcdevito75, If the clutch is hydaulic assisted that unit could be bad, or the clutch reurn spring couls be bad, broke. Ley your local repair shop fix this problem.
Jun 17, 2010 | 2004 Saturn ION
Weedeater gas TE400. Trigger broke (perhaps
120' cord. I would go to a big-box store and investigate making your own cord so that you only have 2 ends. 12 guage at the very least. any thing smaller, and you will burn up the motor.
I believe that the trigger and throttle cable should solve your issue.
530071550 throttle kit $8.16 + 12.75 shipping
Nov 07, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
My ir 223 impact trigger doesnt work ,,,I took it apart ,the pin tha goes thru the body is there but the pin in the airlet is missing and it must be missing a spring too ,it just wants to run wide open all...
You can purchase a repair kit from Ingersol that will have the spring and pin. You will need to make sure the fitting on the inlet that has the screen installed is still there or the pin and spring will come out again
Sep 26, 2009 | Ingersoll Rand Ingersoll-Rand 1/2 in....
My remington wingmasater also broke...
Try this link:
http://www.gun-parts.com/remingtonshotgun/Jan22_03.jpg
Hope this helps. :)
Aug 05, 2009 | Crosman (4032)
Nintendo DS left trigger malfunction
the l and r buttons have springs behind them it could be the spring has snapped and the button has fallen onto the switch. the next time it happens hold the ds upside down if it stops its the spring if it doesnt stop then its the micro switch gone faulty and you would have to open up the bottom casing and replace it, its soldered on the motherboard and is smaller than a pea with 5 soldered joints.
Jun 27, 2009 | Nintendo DS Lite Console
Saitek Cyborg X Joystick Logo
53 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
