Question about Microsoft Broadband Networking MN-500 Wireless Base Station (L21-00001) Router
Cannot disable firewall during setup processing MN 500
I'm trying to setup MN500 using software. After I plugged modems, setup told me "setup has successfully detected your base station." I put all wireless network name, password, etc... then when I click next, it tells me
"if I have any firewall or internet security software, turn off, then restore the factory setting." I did disable all firewall, I even delete McAfee anti-virus program, then restored factory setting which is press and hold small hall as it instructed. However, it keep asking me samething over and over and now I'm stuck.
  • nicsun Aug 12, 2008
    I'm having the same problem. Just wondering if a solution has been found?
This link is no longer existing. I have the same problem, has anyone found a solution?
Posted on Sep 28, 2008
Go to the link below and scroll down to the bottom of the page and download the MS Broadband Network Utility. Run that one as opposed to the one on the cd. http://kbalertz.com/814445/Update-Firmware-Station.aspxher
Posted on Aug 13, 2008
I cant connect to friends on xbox live i have a microsoft mn-700 router
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then contact the Router manufacturer and Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Dec 24, 2010 | Microsoft MN-700 Wireless Router
An error occurs during installation
The CD Setup wizard will fail to complete the installation or sometimes fail to run at all because antivirus, anti-spyware or PC firewall is blocking the installation process.
To ensure a successful installation from the CD Setup Wizard, make sure all security tools are temporarily disabled before the installation begins. Enable back the antivirus, anti-spyware or software firewall once the installation is completed.
NOTE: If setup still fails to complete, check that you have selected the correct operating system in the setup options. You may also try restarting the computer and reinstalling from the CD if the setup fails to complete the first time. If all else fails, try searching for your device model at http://www.linksysbycisco.com/US/en/support/ and clicking on Get Downloads to download the latest firmware.
Nov 02, 2010 | Linksys WRT54G2 Wireless Router
Saying error code 8013013d when i try to connect my internet
What you are experincing is a DNS (Domain Name Service) error,and this can be rectified by;
* Ensure that everything is plugged in correctly. The Network Adapter must be fit securely to the PS2 and an Ethernet cable must be securely connected to the Network Adapter. You will hear the Ethernet cable click into place when it is inserted properly.
Reconfigure your network settings. Insert the Network Adapter setup disc into your PS2 and run the setup utility. Make sure that all of your settings are correct, such as what type of network you have and what the name of your network is.
turn off your PS3 and modem. Wait a moment, then power on your modem. Once your modem has connected to the Internet, power on your PS3 and try again.
Disable firewall settings. If you have firewall settings on your network, they could be blocking the PS3 from getting a connection. Turn on your PC and go the "Network Connections" option in the control panel to disable any firewalls that are activated.
Disable your antivirus software. If you have antivirus software, this too could be blocking the PS3 from getting a connection. Open up your software and disable it and check your PS3 again
All the best,i hope this solves your network problem..
Jul 03, 2010 | Sony Playstation 3 (PS3) Console
I just signed up with at&t for wireless service and my connection keeps dropping after a couple of minutes. i have a MN-500 router and DSL service. as long as i only have my Dell PC connected directly...
Hi... If your running on XP, try theses simple steps:
1. Right-click the wireless icon on the taskbar (lower 2. Left-hand corner near time) and View available networks.
3. Left-click the "change advance settings"
4. A windows should pop up... now go to wireless tab and tick or bullet point "Let windows manage wireless connections"
5. Then click apply. Then try to connect to your wireles router again.
If the wireless tab doesn't appear, the click start and Run then type services.msc then click OK.
Double-click Wireless zero configuration and set it to automatic then press apply and click start to start the service. Then try to do the instructions again.
If you're running on Vista, disable the wireless software provided by your wireless card manufacturer to enable windows to manage wireless networks. Then try to connect to your router again.
Hope it helps!
^_^
Jun 08, 2010 | Microsoft Broadband Networking MN-500...
The base station just won't power up - no matter
You either have a bad cable or the unit has an issue. Don't know if this thing has a fuse in it or not, but if the cable is good (check by metering it out) then your next step is to see if it has a fuse. I'm willing to bet it does not in which case your stuck buying something new that does power up.
Oct 28, 2009 | Microsoft Broadband Networking MN-500...
Microsoft mn500 router: the wireless part stopped working.
  • reset the wireless settings on the router page, call your router tech support to access the router configuration page
Aug 11, 2009 | Microsoft Broadband Networking MN-500...
Caanot establish connection from MN-500 to internet
I don't think it's your router or your computers. If you just replaced your modem it has to be the problem. If it is a DSl Modem you have to imput you account username and password. If it's a cable modem you have to call the cable company and tell them you have a new modem. Which every it is you need to contact your Internet service provider, they are the ones who can help you.
Please don't forget to rate this solution.
Jun 14, 2009 | Microsoft Broadband Networking MN-500...
MN-500
You really shouldn't need the CD. It should be plug and play. Plug the modem in. Plug the router into the modem. Plug your pc into the router. Power up your PC. It should self install.
Jul 16, 2008 | Microsoft Broadband Networking MN-500...
Internet Connection
You know it is not your connection nor is it your modem. Contact your isp and ask them to release and renew your ip lease. Then connect the router and retry. Should be good. Otherwise contact Microsoft
(800)936-3900,
choose 1 from the confusing menu. The line is free, open 24/7 and there is no
waiting. The best part is that they are very knowledgeable and helpful
Jan 09, 2008 | Microsoft Broadband Networking MN-500...
Loosing Connection between MN500 & MN520
If you are using XP, and installed the proprietary WiFi software (not the built in XP software), did you turn off the Zero Configuration Wifi SERVICE? Running both will cause issues with your connections..
Start > Run > services.msc (ok)
Dec 22, 2007 | Microsoft Broadband Networking MN-500...
Microsoft Broadband Networking MN-500 Wireless Base Station (L21-00001) Router Logo
79 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
