Question about Neff W4380X1 Front Load Washer
I have a Neff integrated washer/dryer. The machine seems to turn on and take in water but doesn't start to spin. It sit's for half an hour making clicking noises then will start spinning and finish the cycle. Why does it do this, and can it be fixed?
    Genius:
  • Neff Master
  • 1,460 Answers
Assuming that it pumps out okay then could be the motor.....Check belt is okay not fallen off , next motor brushes, they wear out after around 6 yrs ,
Posted on Apr 01, 2011
  • billyrankin0 Apr 01, 2011
    Yes it does pump out, and the drum was turning yesterday when i put it on an empty load to test it, but today it isn't turning.
  • Gerry Harvey
    Gerry Harvey Apr 01, 2011
    if its not turning, check the motor brushes,are they worn away if so replace.....Normally they are located at side of motor..If your not too sure advice call technician.
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
Neff washing machine stops half way through the cycle and the high water level light comes on
possible hose blockage or filter blockage. when half way through the cycle the machine evacuates the water to replace for rince cycle or to start spin cycle if the way is blocked the water cant go out so the machine can not finish the cycle, and usually the door will stay locked so not to flood, when the water is still in the machine. remove and check the drainage hose for kinks and blockage. also remove and check the filter under the machine. (be careful as this will let out all the water so have some towels or bucket ready to catch the water. once the filter is clean replace and restart your machine.
I hope this was useful.
Feb 15, 2013 | Neff W4380X1 Front Load Washer
My neff 4380 integreated washer dryer's drum only
Hi I have exactly the same problem. Did you get your fixed and if so what was the problem?Many thanksCarole
Apr 04, 2010 | Neff W5340X0 Washer
Neff washer dryer V5360XOGB red led light keeps going round
THIS IS A POWER MODULE FAULT IT WILL NEED REPLACING IT SITS AT THE FRONT LOWER RIGHT HAND SIDE THEY ARE NOT CHEAP.... SORRY
Aug 09, 2009 | Neff W5340X0 Washer
Neff washer dryer has error code e06 and the water wont drain
same problem, just replaced pump and cleared all outlet/inlet pipes (passed water through unhindered, still throws E06 when I try to start.
Feb 24, 2009 | Neff V4380X0 Front Load Washer / Dryer
Water gush in power drawer
You have a seal that is not working right for one. and 2 you have a water pump that is not working. because it is not limiting the water supply.
Aug 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Frigidaire built stacked washer and dryer
There is a thermal cut off on the motor. when it overheats it will trip and not start until the motor cools down. Replace the motor to solve the problem.
Jan 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Neff 5644 - how does it work!??
"e" is economy - ignore this there is a selection of spin speed - most people use the fastest half load is what it says - most people wash a full load so ignore the temp dial just selects wash temp. for normal washes set to 40deg can't remember the symbols on program dial but think they are fairly self-explanatory this machine is just a washer remember to check the filter regularly
Jun 14, 2007 | Neff W5340X0 Washer
Neff W4380X1 Front Load Washer Logo
194 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
