Question about Vacuums
I need to set the pricing on a Polyvend Vending machine. PV 2210
Vacuum has power but wont run
From your question it sounds like the Rainbow will not run on high speed. Very good chance the Controller Asm 120v e2 Silver Gold is bad. Call us when you are able as we can replace at a discounted price if your machine meets the requirements. Contact Us
RainVac
Sep 07, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Fein fmm250q not oscillating.. How do I disassemble the head?
Special be carefull with the 4 torx screws if you decide to disassemble the head because all the material of this machine is very soft before you know its broken its also not a expensive Fein model but a nice machine for that price . take a hand screwdriver with direct the right size to feel if its correct fit because its to late if a screw breaks. yes its having very soft material screws, the head cannot have a disassembling its a complete part and if that is complete but all by all decide if you think its worth to replace beware of the price , the price is marketing technically adjusted for this machine and expensive and not made to dissasemble in a bench vise you can all things try to disassemble but re-assembling with new spare parts is not deliverable. only complete . 1 little bearing gives the little eccentric rash on the head , i have i all the time i repaire tools not one time that a head of this tool was defect if you can move the lever free and smootly you can solvent clean and after that lubricate it again but re connect the bearing fronttop machine between the space in the lever set the head in a bench vise fixated that the lever is correct in the center position , and then mount the machine slowly on the head again and if its run mount a attachment or blade and control it again .
Jun 09, 2015 | Fein Vacuums
How do i replace ball motor
It may be cheaper to get a new machine. Call Dyson or do a Dyson Web search and find out what prices will be.
Sep 19, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
We have a Dixie Narco DNCB 240M/138-6 PE2299 Soda Vending Machine How do we increase the amount per soda?
Check behind the coin mechanism. When you open your machine, pull out the coin mechanism. You will see a set of dip switches there. Go to this page for more help. http://www.vendingadvantage.com/troubleshooting.htm
Apr 13, 2011 | Vacuums
The ribbed belt for the brush broke. When we got
According to the schematics from Bissell on this machine, the "gear" ribbed belt goes between the pump and the brush roller. Tension is provided by the pump. The retainer clip is part of the pump assembly and Bissell only sells the entire pump, part # B-010-7185 PUMP, PROHEAT SERIES UPRIGHTS. We can special order the part at a cost of $34.95, www.govacuum.com We have live chat or you can call 888-468-2210 option # 2. You may also want to make sure the pump sits tight in the machine.
Apr 28, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
How much will it cost to repair
Kinda hard to say. However take it to a vacuum repair shop that offers free estimates. This way you will get a price and if it's not your price shop around. Good luck. save some $$$$
Nov 11, 2009 | Bissell 1699 ProHeat Clear View Upright...
Hoover Canister Pulled Vacuum Cleaner
go to thehooverstore and search for your machine. there are exploded diagrams for all hoover machines with parts lists and prices.
Sep 04, 2007 | Hoover Portapower C2094 Bagged Canister...
Vacuums Logo
176 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
