Question about Jetway A350DMS Motherboard
I have installed a sata dvd writer TSS Corp on to my jetway a350dms motherboard . It is being detected in the bios on bootup but is not being detected in windows XP. I have checked the device manager and there is no reference to the rom at all. It is showing that I need to install the raid driver but xp wont let me install these. regards Geoff
  • Jetway Master
  • 3,606 Answers
Hi, you can download the right driver from here:
http://www.jetway.com.tw/jw/motherboard_view.asp?productid=52&proname=A350DMS
You maybe have to disable the firewall
when you install the driver.
Do you have the latest sevice packs installed ???
If not, run windows update.
If there is a jumper on the drive it must be set as slave.
I can`t se if your mainboard has a sata connection.
Hope this will help you.
Posted on Apr 01, 2011
I have no idea what I am doing. I put in a sata driver on my ide motherboard. I bought and hooked up all cords to connect it and now it only opens and closes. It will not install or read any disc. What...
Thank you for your question.
The fact that it opens and closes means you are very close in getting it to work correctly.
Could we take a moment to sort out the technical aspects of what you are asking/saying?
Sata Driver on IDE Motherboard?
A driver is software that is installed to the Operating System. Do you mean a SATA Converter, so that the IDE connection is changed into a SATA connection? If so, let's move on.
The cords that you connected, is it two (usually)red cords with single black ends at each end? If so, let's move on.
If we have got this far, you will have to enter the BIOS settings to ensure that the motherboard has found your new DVD. If you have your manual it will explain which button to push on initial bootup to enter BIOS. It can be "delete", "F2 or F12', manufacturers are not consistent on this. Once in BIOS you need to make sure all options for the IDE drives are on "auto", makes the BIOS do the work for you.
You do not have to install the DVD, the BIOS recognises the new Drive as a Storage Device like a Hard Drive, no drivers needed.
Although the other thing after successfully getting the drive to read discs is you will need to install the optional programmes such as Power DVD for watching movies and Nero for burning DVD?CD's.
Kind regards
Jun 01, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
How do i setup sata dvd writer on asus motherboard p5s800. It does not see the writer
Hi dtoitj4, You have to find where the settings are for SATA mode in the bios.
Check the jumper settings on the back of the DVD burner you just installed, make sure that it's set for slave.
Let me know for any clarifications.
micro-
Dec 12, 2009 | ASUS P5S800-VM Motherboard
Hi my ASUS K8S-MX motherboard is not detecting SATA hard drive and Sata DVD Writer. Though my IDE hard drive and DVD Writer is working fine. Please help me with this .
Two thing here that can be the issue.
1. Bad Sata controller onboard
2. Sata controller is disabled in the bios.
The Fix
1. Purchase a independent sata controller there like $25 bucks.
2. Try going into the bios under advanced and make sure its not disabled.
I sure hope this finds your Very Helpful vote! Have a Merry Christmas and a wonderul New Year!
Dec 07, 2009 | ASUS K8S-MX Motherboard
Replaced IDE DVD writer with a SATA DVD writer. Powered up XP Pro system, but no drive letter shows up. There is power to the DVD drive, but the OS does not see it. No BIOS updates available from EPoX.
Check your bios settings. If you already have two SATA hard disk drives in your system the bios should also list your SATA DVD writer as third in the list. Make sure the bios list the DVD writer. Remember all SATA drives including SATA DVD drives are all seen as Masters. Check your Boot order settings as well. If windows sill does not list a drive letter for your SATA DVD click, Start/Run and type: diskmgmt.msc in the run window. Assign a drive letter to the drive manually.
Cheers!
Mike
Oct 22, 2009 | EPoX EP-4PDA3I-3 Motherboard
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
PC Does not boot up with LG SATA DVD Writer
Did you try to move the small jumper next to the connector on the back of the DVD writer.
Then try to choose different places to connect your DVD on the motherboard.
Check if you have the right driver or reinstall it.
Hope its help, don't forget to rate.
Cheers
Aug 19, 2009 | ASUS K8V-MX Motherboard
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
Jetway A350DMS Motherboard Logo
52 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
