Question about Philips 32PT5441/37 32" TV
Phiips 32pt5441/37 problem
TV just stopped working. The green light flashes two quick green lights than one, rest and than starts again. I see that some one posted the same code but found no solution. Please help
    Genius:
  • 1,139 Answers
Hello tvpassword,
It sounds like a power supply problem, or at least a startup issue. This might be caused by any number of problems, but I would suspect that it, the problem that is, is in the Horizontal section of your set. If this is the case I would suggest that you get this TV repaired at a qualified TV repair shop, due to the section of the TV that is involved, dangerously high voltages are present and could cause bodily harm if a mistake is made.
If you are going to attempt to do this yourself I would advise that you know electronics before attempting this, if you do not, my first statement stands.
I hope this helps,
Shuttle83
Posted on Aug 05, 2008
65 inch mitsubishi model# 65736 green light blinking
If the TV does not stay on, press the POWER button on the control panel for at least eight seconds to perform System Reset. The TV will turn off. Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost. If this happens frequently, obtain an AC line power conditioner/surge protector.
An unusual digital signal may have been received, triggering a protection circuit. Wait for the light to stop flashing and turn TV on.
Momentary power fluctuation caused the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again
Sep 29, 2016 | Mitsubishi Televison & Video
Tv problem
can you tell in what patter does the light blinks??
Mar 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Stop working - shut him self off
If it is a Hitachi--model number please? The Green LED's are each connected to a voltage source---red one should be on all the time and the others you watch to see if one goes out before the rest or dims after the rest of them are out.
This is a diagnostic tool--points to which voltage is failing and then you follow where it goes to.
May 15, 2012 | Televison & Video
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Replaced lamp. Green standby flashes 50 times, then shuts down
hello when you replace the lamps make sure you fitted the lamp securely and make sure the lamps cover fitted securely aswell
shaun
Dec 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Green light won't stop flashing. Unable to turn off/on or reset.
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Aug 21, 2009 | Mitsubishi WS-48515 48" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi 65711 Trouble
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 14, 2008 | Mitsubishi WS-65711 65" Rear Projection...
Philips 32PT5441/37 32" TV Logo
117 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
