Question about Toshiba (HDD2194) (hdd2194-50pk) 60 GB Hard Drive
Hi i have Toshiba HDD2194, i want to connect it to my PC with USB Cable, please can somebody help me to find which kind of adapter i use ?
  • Toshiba Master
  • 12,061 Answers
OK just go to say, Ebay, or your local PC store, and buy a HDD/DVD, SATA/IDE - USB "Dongle" Pack, they are real inexpensive, simply use the interface that matches your HDD the "Dongle" has BOTH connectors, hook up the Power to the HDD/DVD and hook up to the PC via USB, to the PC, the PC, should "See" the device, and install a "Driver' then it should be available in My Computer, as a normal "Drive".
Example below.
http://cgi.ebay.com/USB-2-0-IDE-SATA-S-ATA-2-5-3-5-HD-HDD-Adapter-Cable-/180550148600?pt=LH_DefaultDomain_0&hash=item2a09a0a1f8
Posted on Apr 01, 2011
  • Ali Aldabagh Apr 01, 2011
    thanks,
    but is that work with my HDD2194 (laptop hard drive) male interface
  • john17276
    john17276 Mar 01, 2013
    Al... It looks like there's an adapter attached over the standard pins of the HDD2194. Pull it off an your standard IDE connection is there. Took me a bit of playing and researching until I saw photos of the drive without at male connector and realized it must have been an add-on.
What kind of cable or usb do i need to connect my hp laserjet 3015 to my pc?
Hi,your printer use 2 different USB and parallel interfaces..I recommend to use USB cable..
Pls visit the below links for these cables..
Just in case ,I have provided an URL for user manual as well.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
USB Printer Cable for HP LaserJet P3015dnhttp://www.amazon.com/gp/product/B004PRSNRQ/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=1278548962&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0001M3QZS&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=04ARKGAPMW24ZWCCBNHN
Parallel to USB Adapter opens new browser window - Connect USB Printer to PC Parallel Port with LPT2USB Adapter ********************
HP LaserJet 3015 user guide - ENWW
www.lavc.edu/it/manuals/printer_hp_laserjet_3015_user_guide.pdf
Use these topics to acquaint yourself with your new HP LaserJet 3015 all-in-one
Jul 01, 2011 | HP LaserJet 3015 All-In-One Printer
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
I have an old HP deskjet 3820 printer and a new HP pavilion desk top which has only USB I/O ports, no parallel ports. Therefore I need an adapter cable to connect my printer to my new PC. Does the adapter...
You can almost buy a new printer for the cost of the adapter you are talking about buying. They have all kinds of adapters: the kind that connects to the flat end of a USB or the square end. Parallel, male or female. Go to a computer store like best buy, they should be able to hook you up.
Hope this helps.
Dec 10, 2009 | Cars & Trucks
Cant connect my SX200 via usb to my laptop
Jess,
If you are runnig Vista, disconnect your printer form your computer, reboot and wait for Vista to come all the way up. When Vista is ready, plug your usb cable into your computer. Vista should then say it has forund a new device and follow the instructions. If Vista does not see the printer, then your USB cable, or one of your USB ports (PC or printer) are bad. Make sure the printer is powered on and ready when you do this.
Mar 05, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Notebook Connection to TV
Check to see if your TV has a VGA or DVI input. If it does then buy a DVI to USB adapter or VGA to USB adapter. Each of the adapters cost around $30-60 US Dollars depending on the quality. Then use male-to-male VGA or DVI wire from TV to adapter, then adapter to PC. Good Luck.
Sep 20, 2008 | Toshiba Tecra M1 Notebook
External Drive won't power on
Actually the simpletech dosent need power adapters so u dont need to check for adapters and if you are connecting to usb2 port the power should be embaded so just connect the single usb cable not the both if using usb 1 then connect the both usb cable to usb port if u have already done this please try to change the usb cables wich is connecting the hdd and the pc something wrog in the cable for sure
thanks
Jun 01, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
How can I connect a wireless adapter to my toshiba portege 660 cdt as there is not a port on it for the usb to fit in to
I am assuming that your wireless adapter is USB and that your Toshiba Portege 660 CDT has a PCMCIA slot. If yes then you would need something like a PCMCIA USB 2.0 Card adapter as shown here. The added advantage is that you would have an extra USB port. Just pls make sure that the PCMCIA USB 2.0 Card adapter you will purchase is compatible with your laptop and has drivers appropriate for your Operating System.
Alternately, you can try swapping your USB WiFi for a PCMCIA version similar to this. Again, pls make sure that the PCMCIA Wireless network card you will purchase is compatible with your laptop and has drivers appropriate for your Operating System.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 09, 2008 | Computers & Internet
Windows media cant play my video
Generally that means there is a short circuit inside the cable. Try changing the USB cable, and if that doesn't work, you might have a problem in the camcorder.
Feb 14, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba (HDD2194) (hdd2194-50pk) 60 GB Hard Drive Logo
480 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
