How do you reset a quartz digi-thermo imo so it gives the high and low reading
How do I care for our silestone kitchen worktops?
We all know that Silestone quartz worktops are the toughest worktop material that need very low on maintenance, homeowners should be aware of the basics of caring for them, so that they can last them for years.
Silestone quartz can be a great choice for kitchen worktops, with its wide range of color and design choices, and the flexibility to be shaped to fit into just about any design. Silestone is one of the earliest quartz surfaces that was manufactured, and continues to be among the most popular choices in quartz. It's non-porous, heat and stain resistant and highly durable, making it one of the toughest materials that money can possibly buy.
Caring for Silestone worktops
  • Don't take resistance for granted -While Silestone is highly resistant to scratching, heat, stains, and chemicals, they aren't foolproof of such impacts. Intense heat, acidic foods, abrasive chemicals, etc.
  • Don't replace cutting boards with your Silestone worktop -Silestone is tough, and is built to withstand kitchen abuse, and you'll have to be very neglectful to cause it to damage.
  • The importance of routine cleaning -Routine cleaning of your Silestone can keep it shining, and at its best. And, cleaning Silestone is a matter of a few minutes a day only.
You may also come across a popular Micro-ban treatment, which is essentially an anti-bacterial treatment for Quartz stones. For more information on Silestone kitchen worktops in London, such as Silestone lyra and more, visit us at Silestone Quartz Kitchen Worktops London
Jun 17, 2016 | Kitchen Ranges
1992 pontiac grand am headlight problems
Check that you have got the correct bulb for the one you replace . They both look the same but one has a single filiment for high beam only while the other will have 2 filiments for both high and low beam. If you are usin quartz halogen will be H1 the other will be H4
Feb 03, 2013 | 1992 Pontiac Grand Am
Hello, my aqualisa shower is working intermittently, water starts and then goes down to a dribble, but not all the time. It is an aqualisa quartz.
If you are not getting any water through your shower it is possible that there is a restriction.
Please note that the air lock test is only neccessary if you're shower is the Pumped Digital Quartz or Quartz Thermo Mixer Shower and that you are on a Gravity Fed Water System (cold tank in loft).
The hose will appear fine from the outside,but the hose has an internal rubber liner which can become blocked/twisted.
To remedy this,unscrew the shower head from the hose anti-clockwise.Place the open end of the hose to it's lowest point (bath or tray).
Turn the water on.The water SHOULD come out in a straight line,if however the water comes out in a V-Shape the liner is twisted and the hose will need replacing.
Air Lock
If there is air in your pipework this will cause low flow and pulsing.To remedy this fault do the same above but run the water on FULL COLD for two minutes and then FULL HOT for three minutes.
If the water pulsates it is the air escaping.If it does this leave it until it corrects itself.
Hope that this info helps you,if it doesn't it sounds like you have a mechanical fault with the processor box.
Aug 24, 2010 | Kitchen Ranges
Fault 14 on rinnai energysaver 556ftr
Hi.
Error code 14 is Overheating error.
The error can be caused by the high limit sensing overheating and cutting off. In that case the thermal fuse may not blow. The high limit can be reset tripping circuit breaker and allowing the unit to cool down with power off.
If that does not work , then the thermo fuse has blown
In fact tis unit has a thermo fuse. (refer to manual).The thermal fuse can be tested reading continuity. If thermal fuse has blown, then replace the the thermo fuse. If the thermo fuse blows again, then there is a condition causing overheating. b260351.gif
Here Full service manual.
Unless you are a trained technician call Rinnai support ringing the number in the manual. Some of testing and repair operations described are not suitable for the home user.
Regards.
Ginko.
May 31, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have full propane, yet a low flame?
check the burners are not blocked and the orffice , check the reg on the tank giving full pressure
May 15, 2010 | Thermos Stainless Steel Gas Grill
What type of replacement quartz bulbs for the under counter lights?
could be 10watt or 20 watt i for under counter lighting. If too high could burn out low voltage transformer assuming its low voltage....12 volt...
Apr 08, 2010 | GE JVM2070 Microwave Oven
Pilot ligt wont stay light
My suggestions,
take the electrical wiring off the terminals of the gas valve one at a time, and clean the contacts with a food grade electronics contact cleaner and degreaser. Make sure all wiring is tight, not loose fitting, and clean. The thermo coupler, or sometimes used thermopile (multiple thermocouples in one) generates a small amount of electrical current when heated. The oil residue on a gas valve's electrical contacts SHORTS OUT THE MINUTE CURRENT GENERATED not giving enough current to hold the valve open.
The next thing, how high is your pilot set? If the flame is not striking the thermo pile properly, if its not directally in the flame, it will not generate enough current to hold the gas valve open. Sometimes a dirty thermo pile just cleaned up with sandpaper will work again (accumulated material acts as an insulator)
If you have access to a very high end electrical meter that is capable of measurung MICRO AMPS (very few) then you should check the actual current ouput of the themo pile.
Another thing, the gas valve solonoid MAY BE DEFECTIVE! IF YOUR THERMO PILE is of the screw in type vrs screwed on type, remove the gas valve end, degrease the inside and also that of the thermo pile surfaces, then use the CLEAN errasser of a pencil to clean both the inside of the gas valve connection, and also that of the thermo pile contacts. NO ERRASSER RESIDUE CAN BE LEFT ON EITHER SURFACE! Do not touch these contact surfaces with your hands because even the resistance of the body oil on these surfaces can mean the differance between it working or not!
The thermo pile or a thermo couple generates a minute amount of current that holds the gas valve on.
PS: and that didn't even cost you a dime, I'm off to an emergewncy service call to fix yet another McDonalds deeping fryer (don't call them beeping fryers cause they beep either!!!)
Nov 24, 2008 | Pitco Frialator SG14 Deep Fryer
Low heatworks, high heat does not.
it sounds like you need a set of thermo switches. one may have stopped functioning. a service tech can test them easily. should be low cost
Jun 28, 2008 | Kenmore 64202 Electric Dryer
Digi 002 rack
easy. Your clock got screwed by one of your audio programs in you system. It Happens when sample rates are mixes up. Leave your digi 002 on it does not set itself other than the factory sample rate setting when primarily switched on, which will remember its last setting if mixed up in an attempt to recover. Leave it on turn your system on. Then turn your system off. Not the digi. just your pc, mac. The software utilizing the previously screwed up sample rate will or should be reset. thus resetting your digi 2 to its factory 44. If it does not work check your software settings for any audio software set as default to run when pc is started ans make sure they are set to play back 44. Never turn your pc off when a program using your digi faulters.
Sep 08, 2007 | Digi 002 Rack FireWire-based Pro Tools LE...
Heating & Cooling Logo
240 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
