Question about Olympia Standard 300 Typewriter
After pressing correction key i could not type again .no ink is there .
  • 300 Answers
During correction the lift-off tape is raised. Please check that it goes down and does not interfere with the printing ribbon.
Removing and reinstalling both is probably the best way.
Posted on Apr 01, 2011
My brother MCF440 cn said that black ink was empty . so i changed it but machine says that black ink catrtridge is empty
  1. Open the ink cartridge cover. Pull the lock release lever down and take out the ink cartridge for the color shown on the LCD.
  1. Reinstall the ink cartridge and lift each lock release lever and push it until it clicks, and then close the ink cartridge cover.
  1. The LCD should then display:
    Did you change xxxxxx? Yes No.
    The LCD should display this question for the color(s) that was replaced.
    BE SURE to select Yes using the up or down arrow key or Dial Pad. If Yes is not selected for the replaced cartridges, INK EMPTY will appear again.
  1. After all the correct selections are made, the machine will then go into a cleaning cycle.
If the LCD displays "No Cartridge", there is a possibility that ink cartridges other than ones you replaced are empty. Follow steps below to check the ink volume. If there are empty ink cartridges, please replace them.
  1. Press Ink or Ink Management.
    * If your Brother machine does not have the Ink or Ink Management key on the control panel, please pressMenu. Press the Up or Down arrow key to select Ink or Ink Management, and then press OK.
  2. Press the Up or Down arrow key to select Ink Volume.
    Press OK.
  3. The LCD shows the ink volume.
    Press the Up or Down arrow key to select the color (colour) you want to check.
  4. Press Stop/Exit.
If the message "No Cartridge" does not disappear, unplug the machine from the AC power outlet and wait approximately 10 seconds, and then plug it back in. If the date and time appear on the display, the issue is resolved.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000300/000036/faq000336_008.html?reg=eu&c=eu_ot&lang=en&prod=dcp350c_all&Cat=11
Link to source:
Jul 06, 2011 | Office Equipment & Supplies
I've just installed both cartridges in my lexmark X4650 printer but they show as empty on the maintenance page
Note that a refilled cartridge will not be able to report its ink level. Check if correct ink level is displayed on your printer operator panel. Press Setup button > Maintenance > Ink Level - check your black and color ink levels. If ink levels are correct, then the problem could be on your computer.
The Print Spooler service on your computer may be disabled. To enable the Print Spooler service, follow the steps below:
  1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  2. Type in "NET START SPOOLER" (this will restart the print spooler service)
Try to check your ink levels again.
Jun 25, 2011 | Lexmark X4650 InkJet Printer
My printer says it's unable to clean 46? it's a mfc printer LC-51 Series ink
Please note that this error code appears when the container in the printer that is responsible for storing used / discarded ink is full or registers as full.
The following instructions will guide you through the process of resetting the printers self clean counter so the error will go away but in the event that the ink absorbing box is actually full and this is not an erroneous message the error message will trigger again immediately.
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Also please note that if the ink box is full and the error code is reset the printer may begin to spill out excess used / discarded ink.
I suggest purchasing a new ink absorber box and installing it.
May 04, 2011 | Brother MFC 420CN All-In-One InkJet...
I placed new ink cartrages in printer and hit ink botton and it just keeps blinking,
First, Make sure you have purchased the correct type of ink for your printer model. Second make sure the cartridges are pressed firmly into place. They should make a "click" sound when pressed into place correctly. Third make sure the cover is closed on the print head and the printer access panel is closed. If you have checked the above try powering the printer off and on again and pressing the ink refill button two times.
Mar 04, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Mfc 5860 red printing green - already checked print levels. all are fine.
1. Confirm that the colors are incorrect by printing a Print Quality Check Sheet
a. Press INK.
b. Press the UP OR DOWN ARROW key to select Test Print.
c. Press OK.
d. Use the UP OR DOWN ARROW key to select Print Quality.
e. Press OK.
f. Press COLOR START
The machine will generate the Print Quality Check Sheet.
2. The LCD will ask "IS QUALITY OK? 1. YES 2. NO"
a. Press STOP/EXIT to return to the "Date and Time" display.
3. Evaluate the Print Quality Check Sheet.
On the Print Quality Check Sheet each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
NOTE: Cyan is the light blue color and magenta is the pinkish color.
a. If the colors on the Print Quality Check Sheet do not match the sequence listed above then the ink cartridges are most likely installed in the wrong order. Continue to STEP 4 to resolve this.
4. Open the Ink Refill cover.
5. Open the cartridge covers of the colors that do not appear in the correct order.
6. Remove the cartridges and reinstall them in the correct slots. On Brother Genuine Cartridges the color of the label will match the color of the cartridge cover.
7. Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink supply tubes with the correct color. One or more of the ink cartridges may run empty during this process. If they do, replace the empty cartridge with a Brother Genuine Ink Cartridge before continuing the process.
a. Press MENU - BLACK START - MENU. The LCD will display Maintenance.
b. Press 7-6, The LCD will display CLEANING ALL
c. Press 6, the LCD will display eINIT__P ALL
d. Press the RIGHT ARROW key until one of the colors that was installed incorrectly is displayed. i.e. eINIT__P CYAN.
e. Press the BLACK START Key.
  • After the machine completes the Setup Purge it will return to the Standby Display.
8. Print another Print Quality Check Sheet
a. Press INK.
c. Press OK.
e. Press OK.
9. The machine will generate another Print Quality Check Sheet.
a. If all four colors printed correctly the issue is resolved.
b. If one or more of the colors are still not printing in the correct order repeat STEPS 4 - 8.
Feb 17, 2011 | Brother MFC-5860CN InkJet Printer
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother MFC 5860cn magenta color is not printing. I printed the test page and did cleaning on it but the magenta color is not showing on the test page. The only colors showing are Black, Yellow, Cayan.
This can happen if the ink dries out for a long time. Try to power flush the color that doesn't work.
press 7 then 6 then 4 then start black copy. This will fill the tubes with ink.
press 7 then 6 then 3 then start black copy. You may use the right arrow to choose the color you want to flush before you press the black copy button.
Press 99 to exit maintenance mode
Press the ink button and do a test print for print quality and see if the color you flushed works. If not, try again.
This is the only way to fix the dried print head. Otherwise you have to replace the print head, in which case, you might as well buy a new printer.
Aug 03, 2010 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean code error 46
All you need to do is to reset the purge counter
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
Feb 03, 2010 | Brother Office Equipment & Supplies
Brother mfc 3360 model mostly problem is no printout, pls soluti
Hi!
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may resolve this problem.
To verify the ink cartridges are installed correctly follow the steps listed below:
Open the ink cartridge cover and reinstall the ink cartridge. Open each lock release lever and push it until it clicks, and then close the ink cartridge cover.
The LCD may then display:
The LCD may display this question for the color(s) that was replaced.
Select Yes or No by pressing arrow keys or 1/2 or "+/-" key.
After all the correct selections are made, the machine will then go into a cleaning.
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will go back to standby mode automatically. Print the Print Quality Check Sheet and see if all colors are present:
Press the Ink or Ink Management key.
Use the up or down navigation key to select Test Print.
Press OK to confirm your choice.
Use the up or down navigation key to select Print Quality.
Press OK to confirm your choice. Press the Color key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 25, 2009 | Brother MFC-3360C InkJet Printer
Ink cartridge
The real problem is that the waste ink tank is nearly full
Correct code procedure for resetting the Canon MP370
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing the black button
with the star (in a
head ?) above it, followed by
scan, copy, scan
2) Select TEST MODE (press right
arrow button 13 times).
3) Select [8] PRINTER TEST
4) It'll now say "- 8-2 +" press
the right arrow key once
to get "- 8-3 +" Hit ok.
5) Select 0. [INK COUNT].
6) Press the ok key.
7) It should return to showing
the "8:
Printer Test - 8-3 +"
8) Press the [Stop/Reset]key -
black key with triangle and
circle on it –
(returning to the state of 3)),
and then press the [ON/OFF]
key.
Good Luck and don't blame me if it
goes wrong !!!!
Now you can print again, but it has not solved your full ink-tank, that has to be solved in future.
Theo
Jul 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Olympia Standard 300 Typewriter Logo
81 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
