Question about Coffee Makers & Espresso Machines
Krups xp 7200 coffe machine. The "calc" light blinking.
  • 2039 Answers
SOURCE: my krups 9000 keeps on setting off the saftey switch at the main powerboard off my home
you mean house breaker i guest you tried the machine somewhere else and if still blowing breaker check the power cord open it maybe with vibration power wire are toughing themself inside machine cheers
Posted on Jan 27, 2008
SOURCE: i need a manual for krups xp 7240, krups xp 7200, krups xp 7230
I have the manual, send an email to me at inouside@hotmail.com and I will reply to you with the manual in pdf format.
Posted on May 14, 2009
  • 1089 Answers
SOURCE: COFFE MACHIEN WON'T MAKE COFFEE
Hi
A blinking red light means that something is not in place. The usual subject is the drip tray. If it doesn't lock into place usually there are grounds behind it. The brew unit is an other one that doesn't lock in every time. To check, open the door and without pushing the "press" button, grab the handle and pull. If it comes out, that was your problem.
Posted on Jun 20, 2009
SOURCE: the hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Allan
Posted on Mar 19, 2010
SOURCE: hello, the spent coffe holder fill up with water
water fills spent coffee holder during coffee making
Posted on May 16, 2010
How do I fix my coffe machine?
Contact the authorized service center.
Jan 07, 2016 | Krups Orchestro Dialog FNF2 Espresso...
Leaking Krups xp 7200 Coffee Maker
It is a Torx T15 screw. Common leak point on those is the barista seal at the bottom of the brewing chamber but that is by no means the only leak point. You need to get the covers off with your new Torx driver and see where the leak is
Apr 01, 2013 | Krups XP Coffee Makers & Espresso Machines
What do you do when it says calc. on the display?
Calc is indicating that it's time to descale the lime build up inside your coffee maker. Most machines are easily cleaned by running a solution of 4 parts water to 1 part vinegar. Run this solution through a regular coffee cycle (no coffee). After running this solution, you may want to run straight water once more to ensure there's no vinegar aftertaste. Your machine will now be clean and the CALC message should disappear. If not, post back with the Model # of your Krups coffee maker for further instructions. Some machines have a Descale or Self Cleaning option built into them.
Apr 24, 2011 | Krups Coffee Makers & Espresso Machines
I need a manual for krups xp 7240, krups xp 7200, krups xp 7230
Mar 04, 2009 | Krups XP7230 Compact Super Automatic...
I HAVE A EXPRESSO COFFE MACHINE MODEL XP4050
Just only I follow the instruction that I read in Fixya with citric acid and resolve my problem,
Thanks
Jan 14, 2009 | Krups Coffee Makers & Espresso Machines
The display reads CALC.
I have a Krups model FME4 and it means that you should descale the machine. Here's a link to the use and care instructions for my model, I assume it would be the same for yours.
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Use+and+Care/ResultUseAndCare.htm?SelectedService=Use%20and%20Care&SelectedGuIDService={EC10140D-AA43-4DCA-8D3A-A5A4823D9E52}&SelectedProdRef=FME4
My problem is that CALC continues to display even after I've descaled several times. Good luck with yours.
Oct 30, 2007 | Krups ProAroma 453-42 Coffee Maker
Coffee Makers & Espresso Machines Logo
65 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
