In my display showing no signal but the motherboard light and the fan are woking properly where would be exactly the problem and how to solve problem tell me.
  • 656 Answers
Remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot if no beeps by removing the memory then remove the processor fan and clean it with soft clot and apply thin layer of heat sink compound and switch on the computer if you still not hear the beeps then change the processor if still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock reset etc in the mother board has gone wrong or not producing them
Posted on Apr 01, 2011
My computer does not Display nothing on screen at all. I realised that the power supply fan is not working. What is really the problem
is it onboard graphics or a card?
the fan on the power supply could be blocked with dust but this will be unconnected
dust could be the problem all round
i need to know if it is the card or onboard
also i have just had to purchase a new card it was fine then i woke up turned the computer on and got no signal atall the ram had just gone over night it happens
please give me more detail
Feb 28, 2011 | HEWLETT-PACKARD HP System Board LGA775 For...
My desktop will not turn on. Monitor shows no input. Fan in tower running very high. No lights on the tower.
In this case if you monitor say no input or no signal it means the monitor connector cord are not connected properly to the motherboard. Or if you have a video card you need to plug your monitor connector to the video card. Because if you a video card and the monitor cord are connected to the motherboard the monitor will not be display. So check the monitor connector if it is correctly connected.
Regards
nicole
Oct 03, 2009 | Computers & Internet
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
Intel D865GVHZ (Gateway Hazelton) motherboard system cooling fan
This fan error message shows up when the CPU fan is not plugged into the CPU FAN plug on the motherboard. The Intel D865GVHZ
motherboard has a total of 4-fan plugs so it is easy to plug the CPU fan into one of the other fan plugs that is not marked CPU FAN on the motherboard.
Apr 12, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
A7V 400MX ASUS Mother Board: Problem
i had same thing - was power supply,,,,replaced and all fixed, now boots properly everytime
Mar 15, 2009 | ASUS A7V400-MX Motherboard
About motherboard
I believe you have overheating problem
Remove side of case and clean all fans including power supply one then clean and remove all fluff and dirt from Heat sink vanes.
Then vacuum out case include all vent holes and behind power supply ones
Then restart computer
Oct 10, 2008 | Intel D865PERL Motherboard
Fuse Locations
dear blankslate,
the green light glowing shows that your motherboard is getting power. check your SMPS first. it can be done
by shorting a green and any black wire(not advisable if you are not a technician). if the fan on SMPS fan rotates
then the problem is with your motherboard(Display problem). otherwise it is a SMPS problem(means power good signal
voltage problem).
thanks,
Sep 22, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
ASUS STRIKER FORMULA
This Is A Processor error Message, CPU ( Central-Processing-Unit ) INT ( Intermittent Fault ) wrong Type Installed. ( Faulty Processor ) Disconnected Fan-Wire To Motherboard ?
Or if It,s INIT Then It Fails To Initialise The CPU.
Is The Board Auto-detect Settings ? Or Jumpered ?
Mike @ Compurepair.
** Please don,t Rate This Post until Your Problem/Issue Has Been Resolved**
Feb 27, 2008 | ASUS Striker Extreme Motherboard
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
