Question about Zanussi ZWF1430W Front Load Washer
Door locked with clothes and water trapped in side. Drum moving slowly and "clunking"
    Genius:
  • Zanussi Master
  • 1,474 Answers
If you remove the drain hose from sink, drop it down low into a bucket,this will gravity drain and allow you to open the door to remove clothes, clunking could be object stuck in the drum or the pump even,at worst Drum bearing failure..Good luck
Posted on Apr 01, 2011
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Forgot to put the lint trap back into LG Ventless Dryer DLEC855W. Clothing might have gotten stuck inside. Dryer now making grinding noise and drum is moving slowly. Is it time to call a repairman?
The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Mar 01, 2014 | LG Electronics DLEC855W Electric Dryer...
My GE Adora side by side makes ice but the water dispenser barely dispenses.
Did you recently move the fridge? One possibility is that the supply line in the back of the fridge is kinked. Usually it is coiled so you can move the fridge out and back damage but if it gets kinked, it would limit the water supply like a hose does when kinked. Also, the supply line is usually tapped from under the sink. Make sure the valve that supplies the line (usually 1/4 inch line) is fully opened. If that fails to help, then you're back to the solenoid valve for water that is not fully opening. Should give a solid clunk when actuated. G
Jan 27, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Clunking banging noise
It may be something stuck in the drum, ie a bra wire, which would have extra weight on it whilst the clothes are wet. If this is the case, it will need looking at sooner, rather than later, as it will just be causing further internal damage
Dec 19, 2013 | Fisher and Paykel Dryers
Upon opening the door after the washer beeped finished, I went to remove the clothes and they were still very wet. I set the dial to "Spin" to remove more water before placing in dryer. The...
the very first thing you have to do is to open door, put hand inside washer inner tub and move tub up and down to see if there is "play" in the bearings. if inner tub moves your main bearing is bad dragging and forcing the motor controller to think there is a "unbalance" condition. also make sure you clean the water pump screen. take small round door at the lower right side and remove the screen to clean. then put it back and retest washer. if that dont work then you may have a fulty unbalance switch or motor controller.
good luck to you.
Feb 07, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My frididaire front load washer is making a loud knocking sound as it goes through the cycle. Also the metal "basket" in which the clothing is places seems to be "off its track" and loose. i can move it...
It sounds like the shocks for the drum are broken. The shocks absorb the wobbling of the drum due to unbalanced loads, etc. Remove the lower front panel (with machine unplugged) and look towards the back on each side and see if you see broken or hanging shocks. The panel has 2 screws I think and should come right off.
Also, if you can open the door and lifting up on the drum inside the machine and moving it around and hear a clunking sound, the drum bearings may be bad. Give that a try and see what you find.
Jun 30, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer will not spin out water but turns during wash cycle
Try cleaning out the trap. It is located under the door and can be accessed be removing three screws at the base in the very front of the washer. The trap is white and screws to open. Watch out though, because if the washer is full of water it will come spilling out! With the trap removed, you should also use your finger to feel the opening of the pump to the side. I found a few bobby pins in my pump, and once they were removed it worked again!.
Jan 08, 2010 | General Electric WBVH6240HWW Front Load...
LG DRYER MAKING CLUNKING NOISE
Clunking could be from bad rollers or cracked drum. Check the drum seam for a crack. If its the rollers you can do the same thing as drum replacement only order the rollers. I got my parts from Sears parts. The below is for a 2514 but should be close for yours.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Feb 10, 2009 | LG DLE2515S Gas Dryer
CLUNKING NOISE - SOMETHING TRAPPED BETWEEN INNER & OUTER DRUMS?
Yes, there is something trapped between the inner and outer drum, you could try removing the sump hose from the bottom of the drum, this will give you more room to fish about than possibly removing the heater. If you do remove the heater, you may not get it back in, then you will have to fit a new one.
The sump hose is the large hose fastened to the bottom of the outer tub.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
53 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
