Question about Samsung Televison & Video
Continues to scan all channels rear projection tv model SP50L2HX
Contacted samsungs web site
Posted on Aug 05, 2008
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
KDF-60XS955 digital anntenna connection
look for a coax cable connection on the back of your tv, connect antenna to booster, booster to tv, then in the set-up menu of tv, go to channel set-up, scan for channels
Apr 20, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Digital tv tuner not displaying picture
. Try putting you tv set to channel 3 or 4. Try your tv in all modes. Check the back also to see if in the right spots with the wires. Check your channel scan status, try it on anntena and try it on cable, run channel scan on both. good luck. Try vcr wires if cable wires dont work. vcr wires are yellow red and white. Try another cable cord sometimes they get old. Try looking at your remote and setting it to tv.
Sep 02, 2012 | Panasonic PT-50LCX63 50" Rear Projection...
My Volume and Channel button won't work and so I have bout 2 remotes, neither of them have worked, one is the RCR311BR remote which has been noted to work for this tv. What else can I do
I have a 2000 model RCA P52923 and I had the same problem occur a couple of days ago. The sound hasn't worked for a couple of years, but the TV is connected to an RCA surround sound to resolve that issue. Most recently, while watching TV, it began to start scanning channels by itself. I shut it off and unplugged it for a couple of days, but each time that I turn it on, it begins to immediately start scanning each channel. Neither the remote, nor the channel buttons on the set are able to stop the scanning, and neither of them will perform any functions, including turning the set on and off.
Any advice would be greatly appreciated.
Mar 11, 2011 | RCA P52926 52" Rear Projection Television
I have a Sony KP-53S35 53 inch Rear Projection TV connected to a Directv Receiver. The TV does turn on, but the screen goes blank and VIDEO 1 is displayed. It will stay on, but will continue to do this. ...
Press any channel button on tv remote to switch its input source as TV to watch tv channels.
As you said, screen shows Video-1 display that means tv is set on input-1 that need to be changed, press channel button on remote or tv front to shift it on tv channels mode.
Let me know if you have additional question.
Thanks.
May 03, 2010 | Sony KP-53S35 53" Rear Projection...
How do I connect antenna for digital tv and program/scan for available channels
Hello Scott:
The unit must have a digital Tuner in it. This model do not come with a digital turner, so you are going to need a digital to analog converter box. And a High Definition Antenna. Once you have obtained these units go to your menu and select setup and switch to the the air mode and select channel scan.
Nov 26, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
Jun 17, 2009 | Hitachi 51F59 51" HDTV Projection...
Magnavox PJTV model 51mp392/17 -pressing channel buttons changes
You need a professional.
Your TV has "lost is mind"
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Philips Magnavox 51MP392H Rear Projection...
TV keeps changing channels by itself
Either the channel up or down buttons on the tv are most likely stuck.
Aug 07, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Televison & Video Logo
Henry  Thomas
Henry Thomas
