I have the Samsung HTDS 1000 system and i get the PROTECTION error as soon as I open it. I've noticed that this occurs only when the 13 pin cable from the sub is connected to the main unit. When I disconnect the 13 pin cable there is no protection error (I let it work without the sub for an hour and nothing happened)!!! I tried to open the main unit to see if there is a fan problem or maybe dust but all was ok. I also used a blower in the sub's fan to clean it from any dust but none of these worked. Could it be a simple option from the main unit's menu that I could discard and have it work? Plz answer cause I don't like giving 50 euro to the service for something as simple as a programming option!
  • 11,800 Answers
The protection message appears only when a short is detected. Since you get this message only with the sub connected it means that the sub is shorted and you will have to repair or replace it.
If you decide to repair you should open it and test the electronics - amplifier and power source - of the sub.
Posted on Apr 01, 2011
Hi all. Where can i order/buy a 13 pin cable (system cable) connecting the dvd player to the subwoofer? Samsung ht tx500 home theatre system.
Look in the manual for replacement part numbers - then google-it to find one.
Otherwise, I did find an ebay listing. search for "samsung subwoofer 13-pin" - 1st listing...
It looks correct, but I certainly can't guarantee it will work.
Dec 29, 2014 | Samsung Audio Players & Recorders
How do I fix a protection error on a samsung home theater system
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Protection error details to many popular electronic devices are given. Samsungs' too is there I did noticed; I recall.
Jul 27, 2014 | Samsung 1000W 5.1-Ch. Home Theater System...
Startup 6 beeps
Probable Causes
Error
Beep Codes
Defective system board.
Memory refresh failure.
Faulty DIMM or defective system board.
Error occurred in first 64 KB of main memory.
Faulty DIMM.
Read or write error occurred in first 64 KB of main memory.
Timer on system board malfunctioned.
Defective microprocesor.
Microprocessor error.
5
Gate A20 failure.
6
Defective microprocessor.
Microprocessor-execption interrupt error.
7
Missing or faulty video adapter.
Video memory read/write error.
8
Corrupted system BIOS program or defective system BIOS chip.
ROM checksum value does not match value encoded in system BIOS.
9
NVRAM shutdown register read/write error.
10
Defective microprocessor or cache card.
Cache memory error.
11
Faulty video adapter.
Video adapter failure.
12
Loose video cable connection or defective video cable.Faulty video adapter.
No monitor connected.
13
May 15, 2013 | Samsung NP-148 NP-150 N148 N150 N128 N145...
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
Mitsubishi vs 6061 wont turn on
More than likely the problem with your TV is cause 2 but check the other also.
Cause 1.
1. SHORT DETECTS SHUTDOWN (PIN 13 OF IC700) CHECK FOR OPEN L902 PART # 351P155010 OFF Q904 C (15 V SUPPLY) ON THE MAIN PCB.
2. SHORT DETECT SHUTDOWN (PIN 13 OF IC700) CHECK FOR SHORTED D913 PART # 264P722010 AND OPEN Z901 PART # 283P039020 (Z905 AND Z900 MAY ALSO BE OPEN BECAUSE OF THIS).
3. X-RAY SHUTDOWN (PIN 55 OF IC700) CHECK FOR A LEAKY D5A09 PART # 264P244030 OFF PIN 6 OF IC5A01.
4. X-RAY SHUTDOWN (PIN 55 OF IC700) CHECK FOR LEAKY D5A21, PART # 264P045040, IN THE BEAM PROTECTION CIRCUIT ON THE MAIN PCB.
5. CHECK FOR LEAKY Q5A03 AND/OR Q5A04 BOTH PART # 260P559050, IN THE HIGH VOLTAGE DETECT CIRCUIT, ON THE MAIN PCB.
Cause 2.
1. CHECK C924 (1000 UFD 36V) AND C925 (100 UFD 50 V) IN THE -24 VOLT SUPPLY CIRCUIT ON THE MAIN PCB.
2. CHECK FOR LEAKY D913 PART # 264P722010, OFF OF PIN 12 OF T900 (15-VOLT LINE) ON THE MAIN PCB.
3. CHECK THE CONVERGENCE OUTPUTS, IC8W00, IC8W01 AND/OR IC8W02. PART # 267P007020 LOCATED ON THE CONVERGENCE PCB. THIS THE CENTER BOARD WITH THE LARGE SILVER HEAT SINK.
Good Luck, Big Irish.
Nov 22, 2009 | Mitsubishi VS-60611 60" Rear Projection...
Samsung ht-wx70 shutting off for protection
The word PROTECTION means that the cooling fan is defective. it needs to be replaced.
Call 1-800-7267864 (SAMSUNG) and they can repair it for you.
Hope this helps!
Jun 30, 2009 | Samsung HT-WX70 Theater System
"Protect" error - HTZ110
Home Theater System Is Displaying "Protection" spacer.gif As soon as the unit is turned on, the word "PROTECTION" will flash on the front panel of the unit and SHUT OFF. This error message usually indicates that the fan in the back of the unit is not on.
The PROTECTION feature automatically shuts down the unit to avoid further damage. The unit will need service if this error message is displayed.
Please use our ASC Locator to find your nearest Authorized Service Center
from samsung's web
http://www.samsung.com/au/support/faqs/supportFaqList.do?group=&type=hometheatre&subtype=hometheatresystems&model_nm=HT-Z110&dType=D&mType=UM&vType=R&prd_ia_cd=03030100&acc_ia_fl=&disp_nm=HT-Z110&menu=faqs
Jan 18, 2009 | Audio Players & Recorders
Samsung ht ds1000 plays fine, but there is no sound.
you have not blown thye fuses the static sound suggests that that is not the problem
Jan 19, 2008 | Samsung HT-DS1000 System
Defective brand new cartridge or defective printer
please give the suggestions for colour printing in samsung- 4200 printer
Dec 26, 2007 | Samsung SCX 4200 All-In-One Laser Printer
100 people viewed this question
 Grubhead
Grubhead
