Question about Nikon COOLPIX S710 Digital Camera
I have dust or lint on the inside of my Coolpix S710, resulting in spots on the images how do I clean this, alternatively is it possible to pull the camera apart
  • 10,515 Answers
This is highly suggestive of faulty CCD sensor. Unfortunately, repair would be more expensive than buying a new camera.You could read more about CCD sensor from :-
http://en.wikipedia.org/wiki/Image_sensor
CCD sensor is responsible for capturing the images to your camera.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 01, 2011
Why does the high limit switch keep tripping
You don't have specifics on the Dryer model. High limit is likely for a temperature being too high, which can lead to damage to the dryer or your clothes, or even to fire.
First and foremost, do NOT work on anything outside of the control panel or drum interior without unplugging the dryer. It almost certainly has a high current, 3-phase power inlet, and you can kill yourself coming into contact with the live power for it. Don't do that!
Most straightforward - look at the vent line. If it's clogged with lint, clean it out, both at the dryer end, and, if possible, for the rest of the line. You'll likely need a flat blade screwdriver to disconnect the vent hose on both the dryer and wall side. Take the vent line outside stretch it out, bang or hand-remove any lint sticking to it. (Stretching will help a lot in getting lint out of squeeze spots in the line.) Wear a dust mask to save yourself a lot of coughing when cleaning stuff.
if the vent is run under your house, go to the outside vent outlet and make sure it's not blocked or clogged.
Complementary to the vent line, clean out any tangible lint in the outlet hole area in the back of the dryer.
Past that point, my experience on the overheat goes a couple of places, all of which involve opening up the back. I'd suggest finding a DIY for your model to cut down on searching for screws. You'll likely have a bunch of 1/4" hex-head screws, which fortunately are the size of just about every hex-bit screwdriver set ever made - just put the hex end of the screwdriver on the head and it'll likely fit.
Inside, you'll open up the top of the blower unit. You will likely find it's clogged with lint, making the air pull anemic. Clean all the lint out of here. There are temperature sensors / cutouts. You'll need a DIY to locate which is which, and likely a voltmeter to test them. Last up-top possibility. Look inside the heater unit. It'll likely be a flat sheet-metal assembly on the right. If it's a gas unit, I'm out of my experience. If it's an electric unit, the heater coils are inside. They are likely covered in lint and laundry room dust. Use a long bottle brush to brush them off, or blow them off with compressed air. (Dust maskt!) A vacuum cleaner crevice tool can be useful. If they're covered in dust, they don't transfer heat to the air well, and can just overheat when the passing air doesn't carry the heat away.
Hope this helps! Good luck!
Nov 07, 2015 | Dryers
How to clean dust from sensor on S710. It gives spots on bright photos
Sorry, but you can't get to the sensor of a point-and-shoot camera.
Jan 25, 2011 | Nikon COOLPIX S710 Digital Camera
Black spot on pictures - cleaned lenses and inside
The spots can be in the inside of the lens settings to the CCD/imager.
If the cleaning of the lens is done well it can be a speck of dust logged in to the screen and having it on the image.
A careful cleaning in a dust proof set up is required.
Sep 25, 2010 | Nikon D50 Digital Camera
How do I get rid of tiny spots that are appearing on my images?
Dark spots are usually the result of dust or dirt on the lens. If a simple soft bristle brush (1/8" wide paint brush is ideal) can't dislodge the debris, you should purchase a lens cleaning kit available from camera stores. They run about $10. These are great to removing these and other contaminants such as finger prints, smudges, etc. High end lenses have special optical coatings and the special cleaning fluid included won't leave a residue - or damage the coatings.
If the spots are bright or colored, (or dark after cleaning above) the electronic sensor inside the camera has a "hot" or "stuck" pixel. This problem is usually not worth fixing due to cost.
I hope this helps - and good luck!
Jun 07, 2010 | Gateway DC-T50 Digital Camera
Canon power shot sd1000 black dot on lens
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Canon PowerShot SD1000 Digital Camera
My cpu overheats
clean the cpu cooler slots and replace the thermal compound on the cpu ....make sure you clean off the old thermal compound .....only a thin layer of new thermal C will do all most see through ... hope this helps my friend
Oct 25, 2009 | Gateway 504GR PC Desktop
Dust spots on images
this will give you the idea how to clean the lens and have lens cover which is available in market to protect it from dust
http://www.picturecorrect.com/photographytips/207/cleaning_camera_lens.htm
thank you
Sep 22, 2009 | Leica M8 Digital Camera
Time needs to be set everytime on my S710
bad battery connecton check for forieng objects in the battery compartment like lint or a spring is notreturning to the correct postion and will need to be pulled out a little bit with a pick, clean both ends of the battery with achocl and the connector ends and retry if this does not work you have a faulty charger or bad battery.
Jun 12, 2009 | Nikon COOLPIX S710 Digital Camera
Spots on image when using built-in Speedlight flash
As is common in many compact digital cameras where the built-in flash is very close to the lens strange reflections can appear in images under certain conditions. Particulate matter in the air in front of the lens (between the camera and subject) such as water vapor (as in a cloudy day), smoke, dust or other items can reflect light directly into the lens causing neutral colored white/grey semi-transparent spots to appear in the image. In extreme examples there may be many of these spots in an image or there may be only one per image. Also, since these spots are completely random they will move or disappear from image to image. For example, if two images are shot consecutively with the same camera settings one image may have spots while the other is clean. To avoid these spots: When possible, avoid photographing in smoky, dust, or cloudy areas Do not use the camera's flash in locations such as above Use an external Speedlight flash if a flash is needed Review images on the camera and re-shoot if spots are visible Cleaning the lens will not have an effect on these spots, as the particles that cause this are not on the lens itself.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Nikon COOLPIX S710 Digital Camera Logo
359 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
