Question about HP DeskJet F4280 All In One Printer InkJet
Printer jam ererr - HP DeskJet F4280 All In One Printer InkJet
  • 656 Answers
If the jammed paper is removed and still show paper jam it means tiny piece of paper is left over in the printer you can use a low pressure vaccum or blower to remove the paper piece before using the blower remove the toner and remove the power plug and the usb connector after cleaning conect the power then the usb then power up printer then in computer click the printer icon in the task bar and remove all the contents then click start settings printer and make your printer default printer right click the default printer and click properties in printer properties click print a test page
Posted on Apr 01, 2011
Ererre c600 km 2035
Are you sure the error isn't C6000, which is a fixing unit error? If it is a C6000 then it maybe able to be reset in simulation mode if the fixing unit hasn't failed. Verify error code.
Dec 23, 2010 | Kyocera Mita RADF-11 REVERSING...
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Paper jam how to repair
In case of paper jam, switch off your printer. Gently try to pull out the jammed paper. Dont force too much if in case the paper is jammed very hard.
There should be a paper jam removing window behind the printer. Locate it. Remove the back paper jam removing compartment and pull out the jammed paper from behind your printer.
I hope this solution is helpful to you
Thanks
Sep 06, 2010 | HP Officejet 5610 All-In-One InkJet...
My printer has the problem of pepar jam
if the printer says its jamming and there is no paper jam.. change the pickup rollers.
if there is a jammed piece of paper then more info would help.
-printer name / model / make ?
-exactly where it is jamming (paper tray, inside the printer when you open it up.?
Jul 21, 2010 | HP Color LaserJet 2600n Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
HP DeskJet F4280 All In One Printer InkJet Logo
53 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
