Question about Microwave Ovens
The built-in microwave went dead as I attempted to screw in a new light. It arc'ed, then there was zero power to the unit. Is there an in-line fuse or circuit-breakers?
  • rgrosso2 Aug 05, 2008
    i was cooking below on the stove and had the fan running on the microwave oven. the microwave oven went out and will not come back on. it did not blow the break box downstairs. is there a reset button to get the microwave to come back on. i tried unplugging it for a few minutes but still nother just dead. i have had the over alittle over a year.
  • Anonymous Nov 30, 2008
    Bosch put a dab of silicone like material on the bulb and socket when installing the bulb when manufacturing the HMV9305. My bulb separated the glass from the metal base leaving me to extract it with a pair of pliers. As careful as I was I did not expect the socket to be "hot" when the counter light switch was in the off position. After the sparks shot in all directions the microwave as dead. I expected better from a Bosch product. Changing a counter light should not be a life threatening or machine ending procedure.
Was cooking on the stove below the microwave and had the fan on. the nicrowave went out all together and will not come back on. it did not blow a fuse in the breaker box. is there a reset button or something to turn back on
Posted on Aug 05, 2008
I have a Bosch built in microwave, HMT35M653B but it went dead today. How can I get a repair manual for HMT35M653B?
Hello and welcome new user of fixya! I found a link to the bosch support page: Bosch Home Appliances Customer Service Support Repair Parts. Try giving them a call or a shooting them an email. Best of luck!
-Mr. W
Feb 25, 2015 | Bosch HMT35M653B Exxcel Stainless Steel...
Samsung smh1816s
If side to side movement restored power, even briefly, the power line connection at the rear could be worn or defective.
Jan 10, 2014 | Microwave Ovens
Samsung microwave suddenly went dead
You have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so there is a paint to repair microwaves for this issue or else just dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Dec 05, 2013 | Samsung SMH8165STE Microwave Oven
MICROWAVE IS DEAD. IT CAME ON FOR 3 SECONDS AND THEN WENT DEAD. NO LIGHTS NO CLOCK NO NOTHING. IT IS BUILT IN OVER THE OVEN. IT WAS MANUFACTURED IN 1998.
sounds like you may have a blown fuse. . remove the 2 screws at the hop thats holding the ventillation grill. remove screw holding control panel. push control panel up slightly and lift out. . there should be another metal sheet covering the opening. remove and your fuse should be right behind that.
Feb 04, 2011 | GE JE1640WA/GA Microwave Oven
Arcing and then went dead. Can see arcing from top vent behind fan blade
owwwww! i say,,,owwwww! again.....
its time you dumped this unit,,,to fix it will cost barn nearly as much as a new one
Jul 01, 2010 | Panasonic NN-P295SF Microwave Oven
Hamburger in foil wrap put in microwave - shorted unit out
Hi- The first thing here is safety. If the power supply is good- 120v at outlet- then address the fuse in the cabinet. Open door, remove screw(s) holding control panel, and tilt out panel. Fuse should be visible. Check for continuity. If bad, replace with 15amp appliance fuse. Plug in and check for operation. If fuse blows again, unplug and start looking at a new microwave. Let me know if this info helps. Have more if needed- Thanks- Ed
Mar 15, 2010 | Whirlpool MH6141XK Microwave Oven
It just went dead. from working great(7 years old
Blown fuse. Remove the outside cover and should be located near the area where the power cord enters the unit.
Jun 03, 2009 | Amana Radarange Microwave Oven
Kenmore 565.6050.9990 microwave dead
Start taking all screws out until you can access fuse.
Sep 17, 2008 | Kenmore 62622 Microwave Oven
Replaced light bulbs, lights still don't work
there is no fuse power comes staight from the transformer on the board. the only possible fuse is the main fuse that will kill all the power
Nov 01, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
EVERY THING WORKS, BUT IT HAS NO HEAT. IT FELT VERY WARM BEFORE IT QUIT
The top switch is not just for the light and the bottom one is not just for the fan. It is not safe to swap wires around. It's a wonder you didn't blow the fuse. All GEs come with an envelope inside that contains a wiring diagram. If the fuse is blown, the entire unit would be dead. If all the switches audibly click, they may be okay, but you also need to check for signs of melting or arcing on the terminals. If the switches are okay then the most liekly possibilites are the magnetron or a loose connection on the magnetron. I will not advise you to work in that area of the microwave. The voltages inside the microwave can be instantly lethal.
Jan 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
123 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
