Question about MSI K7N2 DELTA2-FSR NVIDIA nFORCE2 ULTRA 400 CHIPSET SERIAL ATA150 ATX FORM FACTOR 1xAGP(8X)/5xPCI/... Motherboard
Hi there i have recently reinstalled windows xp home sp2 over the old one and comletely formated the hd, everything seemed to be working but,,,,, 1. it wont play audio, keep getting the message no audio mixer.... (have tryed services.msm/windows audio, start but was allready running fine) its another problem???? 2. i cant get it to recognise the ethernet connection to lan it from the router, (gone into internet opp's and tryed evry thing but it doesn't detect the connection.....? Any constructive advice would be greatfully received ... :)
I lost my audio drive cd how can i get an other one?
Posted on Aug 10, 2011
  • MSI Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver will be on the disc supplied by your ISP internet service provider
hope this helps
Posted on Apr 01, 2011
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I have dealt with a similar problem when I installed a new router. Since my router is used for both hard wire and wireless I had to set a password for the router. Im sure you did to because the password secures your network so another party can not get on your network. Your computer should be asking you for that password. If you forgot it then you have a real problem. You may need to contact the manufacturer via telephone to reset the password. They can walk you through this.
As far as the sound card do you have the latest drivers installed? Also if you a web cam installed disconnect it first then install the drivers for the sound card. Some web cams will conflict with sound cards. I realize your having a connection problem with your internet from your email, but this may help you too. Since you recently reinstalled Window when you install of the updates it may see your sound card and install the latest driver for you.
I hope this helps you out.
Hey, i recently reformatted my mx6453 so im back to the old win xp sp2. reinstalled all my drivers but for some reason it won't recognize an internet connection of any kind. at first i though it w
If your driver are ok then is your computer is in same WORKGROUP like other are(If you are in LAN connection and sharing internet with other).
was there any IP address in your computer before you formatted it? make it confirm and if IP was there then give back the IP to tour connection.
Aug 08, 2012 | Gateway MX6453 Notebook
Deleting old SP1 partition on dell 2400
Sound like you have two versions of the operating system out there. Not sure what your question is. If you want to remove the old version you should have done that while you were doing the installation. That would have been easy by just telling the system to do it for you.
Now you will probably need some type of partitioning software and i'm not sure if you just delete it if it will cause problems when you try to boot because windows knows it's out there.
If I were you, I would just reinstall windows and clean the disk of everything. It shows you what it finds out there as far as operating systems, so just delete them both, then do a quick NTFS format of the drive and reinstall windows.
May 13, 2012 | Dell Computers & Internet
My laptop had previously vista home premium, due to my mini project i hav formatted it to windows xp sp2 my laptop got slow down and its very irritating to use it like that so please hellp me......
Hi
It seems that installing windows XP have no problems
so, i guess the ( windows xp sp2 ) have have problems,
try other cd
It's better if you got XP SP3 insted of SP2, it's enhanced, and more secure.
Please tell us your results
Good Luck
May 13, 2011 | HP Compaq Presario CQ50Z- AMD Athlon(TM)...
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
Laptop Won't Boot
Vaios are prone to faulty Ram ( memory Slots ) The only suggestion i can offer.
Is to remove and re-seat the CPU. this ocassionally solves the problem. if the laptops been dropped or banged. the cpu may have worked loose. but you,ll be looking at either ram or processor. failing this you can assume that theres a motherboard fault.
Thankyou For using Fixya.
Mike @ Compurepair.
Mar 26, 2009 | Sony VAIO VGN-FS715 Notebook
Hard Drive Prevents any other windows device from loading
Hi, Mark Here.
Yes the setup on the xp install puts drivers into memory, but being an older version of windows B4 sta was out it does not have drivers to support it.
You could go to Microsoft & search for a new version of setup install drivers that includes sta, & download to thumb.
Really typical Windows Failure (driver not available freeze up or blue screen).
Mar 22, 2009 | Computers & Internet
Needed to reinstall xp home-sp2 with my recovery cd-rom
Try changing the CD, if that dosn't solve the problem :
1. Format the whole hard disk using the default partition manager.
2. Install XP freshly.
Mar 13, 2009 | Microsoft Windows XP Home Edition
Need Multimedia controller.
If you have Internet connected on your PC then nothing to worry. Just connect it and update drivers. If problem persists, let me know, I will solve it for you.
Mar 10, 2008 | Computers & Internet
Samsung SpinPoint SV1203N 120 GB FHD
Try increasing the actual partition to the capacity numbers in the windows xp formatting , and also format the hard drive using NTFS .
Dec 08, 2007 | Samsung SpinPoint V80 SV1203N 120 GB...
Computers & Internet Logo
82 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
