Question about Sony 1GB Memory Stick PRO Duo Memory Card
My memory stick Pro is not detected by my laptop, under My computer i dont find the memory stick pro at all... please help
    Scholar:
  • 37 Answers
Check to see that the memory stick is installed correctly. If it IS, and you are using Windows XP or Vista, then look under Administrative Services\Tools under the Start menu and select Computer Management. Make sure that the PlugnPlay service has been set up under automatic and that it has been started. The screen will show you a large selection of services and how they are programmed to start. Your computer will read your stick after the correct service, PlugnPlay, has been started. Please comment if this solves your problem. Thanks,
Sciencewoman
Posted on Apr 01, 2011
What could have happened to my memory stick pro duo? I took pictures and was able to view them perfectly fine. When I went to deveolpe them I put the stick in the wrong slot that was too big. The sti
When you plug this memory stick into your computer and the computer cannot detect this memory stick then the memory stick is damaged and your photos cannot be retrieved.
Jan 06, 2013 | Sony 1GB Memory Stick PRO Duo Memory Card
When i formated the Memory Stick pro duo computer stopped and was not complete formatting Stick Pro Duo now not working What can I do?
Hi!
There are 50% chances to make it work again.
It may need a so called low level format. A great tool for low level formatting is from HDD GURU,
please google for hdd guru low level format and download the software. It is very easy to use, but please be very carefully when you choose the drive letter to be formatted, because otherwise it can format even the system disk. If this tool does not detect the card, it is almost sure broken for ever and it need to be replaced.
Hope it helped,
Bogdan
Sep 25, 2011 | SanDisk 2GB Memory Stick PRO Duo Memory...
My memory stick pro duo is not read when I stick it into my memory card slot on my laptop. I do not have the USB cable to hook it in otherwise, is there a way to upload my pictures?
you can buy a All in one USB Card reader/Writer and then insert the memory stick pro duo card in it and plug in the USB Card reader/ writer
to the USB port on your laptop and you should find the same listed under removable devices under my computer. good luck
Sep 13, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
How Can I read my Memory Stick Pro Duo MARK 2 on my Computer? MY problem is I cannot read my Memory Stick Pro Duo Mark 2 on my computer but my computer is showing another Removable Disk(F:),which is my...
    • 1 Visit the Sony Support site (see Resources) and download the Sony memory card software. You will need to specify your operating system. Save the file to your desktop.
    • 2 Double-click the downloaded file to launch the installer.
    • 3 Follow the onscreen instructions to install the Sony memory card software. Restart the computer after completion. Once the computer starts back up, it will recognize the Memory Stick Pro Duo when inserted into the computer's memory card reader. You can browse the files using Windows Explorer or the installed x-Pict Story software.
May 31, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
When i put my sony PRO duo 8gb memory stick into the slot on my computer, the light does not shine green and my computer acts as if it's not even in it. PLEASE HELP A.S.A.P.!!!! Thanks, admlmbrtrckz
Jan 24, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
My Sony Vaio Laptop computer doesn't acknowledge when I insert the Sony Memory Stick Pro duo with the correct adapter in the slot. I used to be able to used this on my laptop; what happened? I can still...
regarding with the issue that you are having with your sony vaio card reader here are some things you can do
- try to perform a system restore and try to restore the computer to a date that the computer is working fine
- try to reinstall the driver for the memory stick pro card reader
- the website for the driver is www.esupport.sony.com
- as far as i understand your issue you are using the card reader port for the memory stick pro
Dec 12, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 17, 2010 | SanDisk 1GB Memory Stick PRO Duo Memory...
    Memory stick pro duo not detected
    ur memory stick could not be detected perhaps the partition of ur memory stick is not FAT or FAT32
    download this tool here is the link:
    http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
    and format it selecting FAT and if it didnt work then Try FAT32.
    hope this will help u .
    Mar 28, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
    I have a Memory Stick Pro Duo 8GB will not open on my computer or camera..was working then quit. Advice please
    Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
    Jan 02, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
    Problem with corrupted files
    Dont panic... Just insert the memory stick in to a card reader and donot try to open it. but make sure that your memory stick gets detected.Then you can use any of the file recovery softwares to recover the photographs with out formating.I generally use the free app "PC file recovery". In case your memory stick is not detected in the first place, then There is no other option other than formatting. But the recovery software can recover 90% of the photos even after formatting.
    If this doesnt work, post back. I will explain in more detail.
    Nov 09, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
    Sony 1GB Memory Stick PRO Duo Memory Card Logo
    Top Sony Electronics - Others Experts
    Sandy Moore
    Sandy Moore
     Grubhead
    Grubhead
    Computer Links
    Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
