Question about Home
Music player unable to access hard drive replace battery cover
5 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: Hard drive replacement
Can only find one manual for this machine and the download is only compatible with Windows ME. The hard drive is located in the front left hand corner of the machine. Look at the front for a retangular panel, held by two screws, that slides out. Also, with some of the older Toshibas to acess the drive, you had to remove the plastic that surrounds the keyboard, holding the mouse buttons.
Posted on Jul 22, 2008
SOURCE: SLY Electronics Model # sl314cm/Accessing music
It all depends on how you put it onto the player. Go to my computer, SLY, AUDIO, and then copy paste the music you want onto it. If you're downloading the musice off the internet from a place like spiralfrog.com it won't work because the music has no appropiate license.
Posted on Apr 08, 2009
  • 21 Answers
SOURCE: changing hard drive. hard to access it
Download the Service Manual on this page. It might have the answer to your problem
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64180&taskId=130&prodTypeId=12454&prodSeriesId=403745
Good Luck.
Posted on Jul 24, 2009
xuehonghong1
  • 233 Answers
SOURCE: my Nokia n91 4Gb hang anytime i replace the battery cover
If your phone always hangs, I think that you can try to boost your phone with some apps, for me, I'm now using this applock. LEO Privacy Applock Hide Safe Android Apps on Google Play
Posted on Dec 23, 2016
My computer won't recognize it when plugged in. Unable to download music to it.
It should end up in Windows Explorer - File Explorer as a Volume, a temp hard drive. You drag your music files to that drive.
No Software or Drivers came with it?
Make and Model please?
Jan 01, 2016 | Audio Players & Recorders
My computer recognizes this hard drive, but windows media player does not
With Windows Media Player open, hit the F3 key. You get an Add To Library window providing you with an option to sync folders from other sources...like an external hard drive.
Select the option to add My folders and those of others I can access. Then you click the Add button.
Now you can see the Add Folder window. Search for the folder where you stored your music on the external hard drive and select it. Then click the OK button.
This will add the selected folder on the external hard drive to the list of synced folders. Once the Add Folder window disappears, Windows Media Player starts syncing the music and adding it to it's library.
Aug 14, 2015 | SmartDisk FireLite Computers & Internet
Unable to connect my blackberry to wifi. it says unable to authenticate network.
Try a hard reset: With power ON, remove the back cover and pull out the battery. Wait about a minute then replace the battery and cover. Power up and wait patiently through the long reboot 5 minutes.
Also check the wifi encryption is compatible with your phone?
Maybe an option to goto a cafe with a wifi hotspot and try logging in there ... does that work?
cheers.
Oct 22, 2013 | D-Link Dlink Dir-600 Wireless Router...
How do I get the cover off so I can replace the hard in my Asus M70V.
If you are replacing both hard drives, there is the primary located near the battery, just to the right. There are two small phillips head screws under two rubber cover4s. Gently pry them off with a small standard screwdriver and you can see the screws. Then you can access the drive. The second drive is located under the large panel with the model number sticker on it, there are 6 phillips screws to remove and then lift the cover off. There is an indention on the cover near the battery compartment where you can pry it off.
Apr 13, 2010 | ASUS (90N804SH021) Hard Drive
IX260 hard drive
Hi:
I am reasonably sure that the hard drive accessed thru the battery compartment. You remove teh battery cover, remove the battery, and the hard drive is then able to be removed.
Nov 06, 2009 | Itronix GoBook III IX260 Notebook
My Nokia n91 4Gb hang anytime i replace the battery cover
u had better to update it............. or format..
format code *#7370#
thank u.....
May 11, 2009 | Nokia N91 Cellular Phone
Recovery problem
Stuck in recovery mode Zen v
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
I actually had this exact problem a little while ago with my Zen Sleek-- Booting straight to the Recovery menu, and only getting a generic "Harddisk problem" error screen any time I would try to do anything.
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt.
Mar 18, 2008 | Creative Labs Zen Micro MP3 Player
Ipod clikcing noise
My son's unit did the same thing. I was told it was the hard drive, so I replaced the hard drive and battery and now it is good as new. (Replacing the hard drive is really quite easy if you carefully follow the instructions that come with the kit and have the right Ipod cover removal tools that also came with the kit. I bought mine at Apricorn.com and was very happy. Not inexpensive, but cheaper then having Apple do it. I also upgraded his 30gb Gen 5 to a 60gb while I was at it.)
Jan 02, 2008 | Apple iPod MA446LL/A MP3 Player
I have Sanso m250 2.0gb mobel. Logo screen is appearing when i power on after that i am unable to play the mp3 songs or play FM Radio etc..
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players. You can start over with your playlists. This has worked for me.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
Home Logo
20 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
