Question about Zanussi ZJ1217 Front Load Washer
My machine fills with water it drains it spins there seem to be a problem with the programmer
  • Zanussi Master
  • 17,129 Answers
You must recheck with another program and if the cycle goes on without the correct sequence then the program controller unit is faulty.
make sure that the connections are firm, the motor is manually moving and the water level sensor- pressure switch is in order.
consider the cost of a new program controller and confirm the fault, before you buy.
Posted on Apr 01, 2011
Testimonial: "thanks"
SOURCE: indesit w113 fills with water and then dial just spins to number 9
test the element
Posted on Jan 15, 2008
SOURCE: Washing machine will not drain
Will the water in tub come out when you take off the hose?
Posted on Mar 22, 2008
SOURCE: bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Posted on Aug 31, 2008
barkencoa
  • 3463 Answers
SOURCE: Will not run wash properly
The sensor you are referring to could posslbly be the water level switch which controlls the level of water,and also. is a factor as to wether the washer will spin or not, it also is part of the heater circuit, so it has numerous functions.
I t can be found at the top right front of the washer, and is about 3" in diameter, and has a thin plastic tube going to it.
it could be sticking, there is no sure fire way of testing it properly, but you could try tapping it and blowing down the tube, it may solve the prob.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Jan 04, 2009
SOURCE: Wont drain or spin is lock up
does not spin all water out, towels are still wet, not overloading, could it be the timer?
Posted on Mar 07, 2009
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
GE Washer WBB2090F1WW will not fill and will not spin. Where do I start to troubleshoot as these seem like unrelated problems? Thank you for any assistance.
Both are initiated by the programmer unit? Is the water supply getting to the machine, has a tap/valve inadvertently been closed. i If water is getting to it then if the programmer is working correctly the pump should trandport the water? If water is not being introduced the machine will not rotate.
I think the issues are both associated with a faulty programmer probably
Jun 05, 2015 | Washing Machines
Bosch washing machine fills with water throughout any cycle
Just a guess but could the fill valve be defective, not shutting off completely when it should?
Nov 21, 2013 | Bosch Washing Machines
My machine fills but wont spin or drain
The problem will be in the timer kindly replace the timer to solve your problem
Jan 03, 2010 | Washing Machines
The washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
May 29, 2009 | Kenmore Washing Machines
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
We have a Bosch Exxcel Washer Dryer and it seems that at the end of any programme, the washer does not drain and spin (but does drain and spin in independent programmes) - it just continues at 0.01 mins...
would try cleaning your pump and sump as when its draining without the force of the spin the pump is idle but with the force when you put on other programs ie the spin this will push the water through the pump hope this helps
Jun 22, 2008 | Washing Machines
Zanussi ZJ1217 Front Load Washer Logo
213 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
