How do I unlock this DVD player to play all regions? Thanks
    Brigadier General:
  • 8,909 Answers
Try www.dvdexploder.com/
I hope that helps.
Posted on Apr 01, 2011
I have a Phillips DVDR70 player. It only plays dvds bought in UK. I have some dvd's I got from USA and can't play them. Is there any way to overide the operating system which will allow the Us dvd's to...
You need to unlock the player before it will play discs from other regions. UK has region 2 discs while the US has region 1.
Search on Google for your DVD model and unlock code.
Dial in the code using your remote and you should then be able to play any region discs from around the world.
Apr 30, 2010 | Philips DVDR70 DVD Recorder
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Unlock sony DVP-FX720
The problem may be you are trying to play DVDs from a specific region (Europe) and the player is set for another region. Region code errors will show up as "no Play" or 'region" Check the manual to see how to set the player to Region 0. A region machine will play any DVD. Sometimes the setting is on the menu - usually in the set-up screen under "region." I have re-set all my Phillips players to become Region Free through the menu.
Aug 22, 2008 | Yamaha DV-S5450 DVD Player
PANASONIC DVD RECORDER DMR-ES35V
DVDs are region coded. This means that they will only play on a DVD player from the region the DVD was produced to be watched in. For example, an Australian DVD is Region 4. It will only play on a Region 4 player. If you try to play it on a player that is set for a different region, it will probably not play. One way around this is to get hold of a multi region player. These are widely available. Alternatively, you should be able to watch the DVD on your computer, although you may need some region free software if your computer's dvd player has been locked. Usually computer DVD players will allow you to play DVDs from any region a few times and then they will lock to a particular Region Code. If you are in North America, you will need a PAL player. The only other thing you may be able to do is to unlock your existing player to convert it to region free. Many DVD players can be unlocked but you would need to find the unlock information for your paticular player. Hope this helps....
Jul 27, 2008 | Panasonic DMR-E55 DVD Recorder
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
REGION 2
1/ Power ON
2/ Press PLAY
3/ 274222222005255
4/ Press Play
5/ Power OFF
Apr 22, 2008 | Yamaha DVR-S150 DVD Player
Region unlocking for a Sharp DV-NC80
I would like to play Area 1 DVDs on our Sharp DV-SL 1200 DVD player - please help us unlock it - Many Thanks
Apr 10, 2008 | Sharp DV-NC80 DVD Player/VCR
Unlock DVD Region code Many thanks DAC
i have got teac 3120 , but it only plays pal 2 ...could you help me to unlock region 2 ....so i can have both region 2 and 4 to play/watch
Dec 18, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
