Question about Canon PIXMA MP470 All-in-One Printer
Canon mp470 won't print in black, just installed new cartridges (yes they are refills, but I have used cartridges from the same place before with no problems), test print shows color, but no black.
  • 6 Answers
SOURCE: reset Ink levels for canon mx310
To Reset the Canon Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Any problems contact me on charmed_halliwell@hotmail.co.uk
Posted on Feb 23, 2008
TampaNative
  • 778 Answers
SOURCE: refilling canon iP 1880 color cartridge
The kit should show which are what color, unless it's a generic refill kit? You could try the kit manufacturers site to find the directions for your particular cartridge also.
Hope this helps, and good luck.
Posted on Jan 23, 2008
nitinbabbar
  • 55 Answers
SOURCE: HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
thnx
Posted on Jan 28, 2008
SOURCE: I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
thanks this is helpful
Posted on Aug 09, 2008
  • 4088 Answers
SOURCE: Canon MP470: "Print Head is not installed. Install Print Head"
Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
Posted on Jul 17, 2009
Canon mp470 can't accept refilled cartridge
Canon mp470 is an excellent printer.I will always recommend using original catridges in your printer.Refilled catridges are not accepted by the manufacturers.Let me tell you i used to work for HP in the beginning of my carreer. I have seen that HP refused to accept refilled catriges. hence i would reccommend you take a cotton cloth ,remove the catridges from the printer.Clean the print heads using that cotton cloth n then reinstall the catridges back .......
Lets see if this resolves the issue
With Regards,
AsitRoutRocks
Dec 17, 2013 | Canon PIXMA MP470 All-in-One Printer
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
Just installed new ink and it says i need to install print head, what is this?
Usually this means that one or both of the cartridges is not correctly installed. Remove the cartridges and reseat them. Make sure that you do not touch the contacts and nozzles on the cartridges. If you are using refilled or non-Canon cartridges, try a set of new Canon cartridges.
Make sure the cartridges are in the correct slots and push each cartridge forward until you hear a click. Then close the unit and let the all-in-one preform its start up operations. For pictures, see your manual or the Canon support site: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp470#ServiceAndSupport and search "install print head". The first result has the pictures you need.
I hope this helps.
Jan 31, 2011 | Canon PIXMA MP470 All-in-One Printer
How do you reset the ink levels after refilling them on a Canon Pixma MP470 ????
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Canon PIXMA MP470 All-in-One Printer
Jul 17, 2009 | Canon PIXMA MP470 All-in-One Printer
Refilled ink cartridge wont work. Getting message saying ink is l
Many 'refilled' cartridges aren't refilled. Try a new c artridge and see what happens. If it still doesn't work, you need a new print head.
May 23, 2009 | Canon PIXMA MP470 All-in-One Printer
Mp470 pixma
Do you still need help with this problem?
Regards,
Worldvet
Nov 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Printer error on a canon mp 470
How I can fix the U051 problem with my conno : MP470 printer ? It says the print head is not installed. Install the print head. Where is the it , and how I can fix it?
please e-mail to atvandparts@gmail.com
Jul 26, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon PIXMA MP470 All-in-One Printer Logo
446 people viewed this question
old marine
old marine
