Question about Huffy Cycling
Is there a web sit e or other material i can get on the cranbrook beach cruiser what i need is a detailed explantion on removing and insalling the rear hub with a coaster brake assembly
    Brigadier General:
  • 8,546 Answers
Most bikes are just static frames with a bunch of aftermarket stuff hung on them.
Everything on a common bike is found on just about any other brand of bike and the individual components are usually documented at the manufacturers' websites.
Places like http://www.parktool.com/blog/repair-help document many of the repair and adjustment procedures.
Google will find tons of How-to videos.
If it's Shimano try http://techdocs.shimano.com/techdocs/index.jsp
Posted on Apr 01, 2011
Why is my 29 inch huffy beach cruiser making a kinda loud clunking nice when i ride it . ive been having problems with the coaster brake ive tried to tighten it with a hammer and even disasemled it an
Your problem sounds like the brake assembly inside the hub is bad. If you bought the bike recently, take it back to the retailer. For proper repairs for this problem, I suggest taking your bike to the local bike shop.
Sep 05, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
Two banging sounds with each rotation
Most beach cruisers have a chain guard. There is always a slight "wobble" of the front chain ring, check to make sure the chain isn't slapping the chain guard. The chain guard can be adjusted. The chain also might have loose tension causing it to bounce around just enough to hit the chain guard. The opposite may be true, if the chain is too tight, you could be getting a popping sound at certain points on the chain as it messes with the gear teeth, in this case loosen the chain slightly to put a little slack in it.
Jan 14, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
Need size for huffy cranbrook pedals
I am going to provide a link to a video that will show you how to determine the correct size of pedal for your bike. Identifiying the Proper Size Pedal for Your Bike
Oct 02, 2012 | Huffy 26 in. Cranbrook Cruiser Bike
Want to know the correct way to put the bearing assembly back together correctlytimtrs1
Whihc bearing- there are several on a bike. Try this as a start then go web surfing for more ideas. Many people post good videos for how to do things.
Sep 17, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
My pedals broke on my huffy 26" cranbrook cruiser what size and threads are the pedals
All are the same size ... they come in Right hand and Left hand ... dont try to change them. Left is as seen from the rider seat.
Sep 05, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
My Huffy Cruiser Cranbrook has the rear tire flat. Does anyone know how to take the wheel off so that I can replace the tube? Thnak you.
Loosen the axle nuts on both sides. Slide the wheel forward to disengage the chain from the gear. Now pull the wheel up and out the back, sliding the chain over the axle as you bring it out. Hope this Helps FixYa up.
Sep 03, 2011 | Huffy Cranbrook 24Inch Cruiser Bike
My chain is slipping off. I have new cranbrook cruiser. Any tips?
Web search "chain slipping off" for some ideas to better define and visually analyze what is really happening and maybe find the solution yourself.
Aug 09, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
My Cranbrook bike makes a clanking noise when I pedal it.
You need to evaluate wuith your eyes and ears what moving parts are contacting other parts of the bike in an undesireable way. So, what moves when you pedal it? The crank and chain.
Jun 30, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
Is there a web site or other material i can get on the cranbrook beach cruiser what i need is a detailed explantion on removing and installing the rear hub with a coaster brake assembly
Yes, http://www.huffy.com/ is their website.
Should not be all that difficult but you will need a few different wrenches. One for the wheels axle nuts and one for the coaster brake assembly. All coaster brakes work the same, so any coaster brake manual will work. Your local shop can also show you how to remove and install the wheel.
Apr 01, 2011 | Huffy Cycling
Bottom bracket bearing failure
Take it to a Local Bike Shop and have them evaluate what's compatible with it.
Apr 22, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
Cycling Logo
149 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
