Question about Canon Office Equipment & Supplies
The printer is not recognising cyan ink cartidge CLI-BC even though it is full
  • vaalwill Aug 06, 2008
    Thanks for your reply to my problem but I cannot get the printer to do a nozzle check or a head cleaning. It keeps coming back with the message that the printer is not recognising the cyan ink cartridge. I have taken it out and put it back several times. The printer was not out of ink for any length of time.
    My printer is a Canon Pixma MP970
  • 659 Answers
Try doing a nozzle check to see which colors are getting through the printhead. If you are missing lines in the pattern or there is no ink color showing, you will have to do a head cleaning. Was your printer out of ink for any length of time? If so, it is a clogged printhead. some printers are designed in a way that will not allow you to print at all, if you are out of a color. They do this for a specific reason- If you were allowed to print in black and you were out of yellow and you did this for a month and then replaced the yellow, you would have a clogged printhead. Why? Because there is a reservoir in the print head and if you do not replace the ink, after a while, the ink in the reservoir will dry out and you will have a clogged printhead. The only way to fix this is to do a head cleaning (2-3-4, depending on how bad the clog is) and that uses a lot of ink. So, Epson does not allow you to print if one color is out, to save you the time and expense of having to do a head cleaning.
Did you remember to take the tape off the top of the cartridge? If so, run a few cleanings and do a nozzle check. If there is still no cyan, your print heads may be clogged
Posted on Aug 05, 2008
  • Wesley Gardner
    Wesley Gardner Aug 06, 2008
    ok whats the make and model of your printer please
Requires correct printhead but the one there has been in use for ages
Dear
The Canon Pixma MG5150 series inkjet printer takes the following ink cartridges
  • Pigment Black ~ PGI-525BK
  • Photo Black ~ CLi-526BK
  • Cyan ~ CLi-526C ~ "the blue one".
  • Magenta ~ CLi-526M ~ "the pinky one".
  • Yellow ~ CLi-526Y
Thanks.
Jan 07, 2015 | Canon Pixma Mg5150 All-In-One Colour Photo...
Requires correct printhead but the one there ihas been in use for ages
  • Yellow ~ CLi-526Y
Thanks
Error code U150 The following ink tank cannot be recognized
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
Dec 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Feb 22, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Can't find where the ink cartridges are on the cannon mp830 to replace
THE INK CARTRIDGES :
This multifunction printer is compatible with all of the following ink cartridges. Here is a list of these cartridges and how they you can get them:
PGI-5 Pigment Black
CLI-8Bk Black
CLI-8C Cyan
CLI-8M Magenta
CLI-8Y Yellow
All of the ink cartridges are easy to install and/or replace; all you have to do is keep the printer ON, then open the cover it will come in the position and then unlock the cartridge which allows you to remove and replace the cartridge.
These cartridges cost any where between $10 and $15 each. But if you want a good deal, I would suggest purchasing your ink supplies from Costco Wholesale as they provide good prices on packages.
Jul 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
How do i change ink cartridge
open the front panel just lift it u can see the catridges inside that
remove those by just pushing them downwards you can see the instructions of how to remove inside itself in a corner of your printer
try it and buy new catridge and replaceit
or else refil it with the proper advicer
thank you
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Brother DCP-130C
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000030/faq000230_009.html?reg=us&c=us&lang=en&prod=dcp130c_all
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000087/faq002487_000.html?reg=us&c=us&lang=en&prod=dcp130c_all
Apr 13, 2008 | Brother DCP 130C All-In-One InkJet Printer
MP530- Printer issue
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
Ink Tank Order Install ink tanks in the correct order (from left to right) CLI-8BK (Black) PG-5BK (Pigment Black) CLI-8Y (Yellow) CLI-8M (Magenta) CLI-8C (Cyan) mp500_inktankorder.gif 05sj00141_08_en.gif
Jan 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
No Yellow Or Cyan Ink
Hi do the following and hopefully it will help you. If it doesn't then you have a fault carriage or main PCB.
  • Remove ink Cartridge
  • With a soft cloth wipe clean the gold contacts on the carriage unit and the same on the ink cartridge
  • reinstall the ink cartridge
  • Click start
  • Select printers and faxes
  • Right hand click on the printer icon
  • Select Properties
  • Click on Services Tab
  • Click on clean print heads
  • Then click on Prime.
Hopefully this will work
Thanks J
Dec 01, 2007 | HP DeskJet 990cxi InkJet Printer
129 people viewed this question
old marine
old marine
