Question about Acer Aspire One PC Notebook
My netbook doesnt show any wifi connections how can they show up again?
    Sniper:
  • 113 Answers
Try to check if your Wifi switch is turned "On". I got the same scenario before on my laptop, and found out minutes later that my Wifi is off.
Hope this helps.
Posted on Apr 01, 2011
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 65 Answers
Install wireless driver and enable wireless using function keys or button..
Qzd netbook says its connected t wifi but when i nclick on internet it doesnt work
normally if u look at the icon on your keyboard to turn it on use FN+WHERE EVER IS THE ICON TOGETHER
Sep 25, 2013 | Acer Aspire One Netbook 8.9" Notebook
I have a epc netbook and i have wifi connected but the othe computer has an x on it and its not letting me connect to the internet. Its a windows ce 6.0
try clicking on it and have it run a check on your wifi plus make sure it doesnt have a switch on the side if so turn it on..
Apr 15, 2011 | Computers & Internet
Have an acer Aspire One netbook and for some reason I cannot connect to the internet even though it is saying that a wifi connection has been established. This has never happened before
If you are connecting on an open WiFi (does not have WEP or WPA enabled), then make sure you are connected to the correct SSID (wireless ID) and not on some other open SSID. If you are on the right SSID, check that you don't have limited connectivity due to low signal strength. If OK, then open Internet Explorer to use its Diagnose Connection Problems tool...
1. click on Tools tab
2. click on Diagnose Connection Problems...
3. click on Next button and follow the steps
If unsuccessful, try powering off the wireless router and the cable/dsl modem for a few minutes and then powering up the modem first followed by the wireless router. Once the netbook has re-established the WiFi connection, repeat the above procedure to Diagnose Connection Problems. Finally, if still unseccessful, connect directly to your wireless router using an ethernet cable from one of the four RJ-45 LAN ports on the router to the netbook's 10/100 ethernet RJ-45 port on its left side. A LAN connection icon should now show in the bottom right of the Desktop's Toolbar. Hovering the mouse cursor over it shows the Local Area Connection pop-up with Speed and Status. If Status is connected, then open Internet Explorer again and use its Diagnose Connection Problems tool to check connectivity to the internet. If still unresolved, the next step would be to log into the router to check its WAN status and depending on the results, you may have to contact your Internet Service Provider.
Jan 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
The wifi is turned on but there is no wifi icon at the bottom panel of my netbook. i cannot locate the connection management settings.
in control panel go to network settings you will find it in there right click on the wifi connection and go to properties, click the check for show when connected in taskbar then that icon will be on your taskbar at the bottom
Jan 11, 2011 | Acer Aspire One Netbook 8.9" Notebook
Netbook connected to my WiFi, but Explorer won't go online.
Make sure you are entering the correct WEP key or password for your network. It might show you are connected to the WIFI but will not let you go online. Also, make sure the settings in internet explorer are set to "Automatically retrieve settings"
Jan 02, 2011 | Sylvania G-Netbook
Bought a 7" allfine netbook
what type of internet connection do you have at home?.
First, Try using an ethernet cable from the notebook to the router (modem)
Before doing do disable the wifi connection
To disable the wifi connection,
go to the network connections folder which you will find on your start menu or control panel
select the wifi connection right click on it and say disable
Dec 27, 2010 | Computers & Internet
I can turn the wireless "wifi power" on but the wifi icon does not show - it will only show when the wifi power is OFF - I have no way of connecting to my home wireless system. Do I have a defective...
situation 1 :- if your (ur) notebook wifi driver are pre-installed by ur operating system then there may be the case of wifi hardware problem
situation 1 :- if not then check if the wifi driver are installed or not....
re-install wifi drivers . and even the problem persists, then please contact ur notebook manufacturer (for free repair if ur notebook is under warranty time period)
Sep 19, 2010 | Sylvania G-Netbook
I bought the new sylvania 7" laptop. I am having problems.. We have connected to our wireless router however, we not get on the internet...
from another computer, go to the routers configuration screen and make sure the status shows that it is connected to the internet. Also the routers internal LanIP address must be 192.168.1.1 for the netbook to work.
I just purchased a Sylvania Netbook. Following the Quick Start Guide included in the package, I went to set up a WIFI connection. The first step is to "click the WIFI icon on the lower right side of the...
should work. make sure the radio is on from either the desktop (not the task bar) or the f9 key. You might need to select the router connection and enter the pass key if locked.
Sep 08, 2010 | Sylvania G-Netbook
I am unable to connect my acer aspire to a my existing wireless connection
I have two Acer Aspire One Netbooks: x1 10.1" and x1 8.9". The switch located on the very front right edge of these Netbooks is quite tricky to get it to actually switch the WiFi radio ON / OFF. Double check that switch position and since it is spring-loaded, you will have to try to see the tiny green light flickering if WiFi radio is active. The green ON (active radio) lamp is TINY and dim at best even when Brand new.
Also, if I have had the radio OFF and / or the Wireless connection 'disabled" on purpose, both of my Netbooks require a full hard boot before they will again connect to WiFi.
Hope this helps!
Good Luck
MFied
Lakeway, TX
Apr 19, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One  PC Notebook Logo
156 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
