Need codes for philip magnavox tv so i can program one for all access 4
    Novelist:
  • 159 Answers
Hi, after extensive research at oneforall-na.com I click on the service and support link, then hit the " find your setup code " link-to finally be asked for a " URC number " which is indicated by a flashing vertical line. Not knowing where mine is presently I would guess that number is on the back of the remote, maybe inside the battery compartment somewhere, or even in smallish print somewhere on the front-not to worry though from what I've seen online that number will have " URC " in front of it. once you have located this number you can go to their website and hopefully download the manual for yourself. By the way, If you open up a second tab this'll allow you to view this and one for all's site kind of simultaneously. I hope I've been enough help, good luck, Prodzilla.
Posted on Apr 01, 2011
I need code for philip s remote for a sayno ty
Philips rca universal remote codes sayno vcr dvd combo ...
www.fixya.com > ... > Remote Controls
Universal Philips Magnavox remote for a Sanyodvd vcr combo ? I have a cableremote and need to program my Magnavox vcr/dvd combo into it i have 2 dvds ...
How to Reprogram a Philips Universal Remote Controller ...
science.opposingviews.com > Computers
Dec 21, 2015 | Philips Televison & Video
Please, Access 4 One For All remote URC-4700B00 4 digit code for a Magnavox Tv Mdl# PR 1910 C123 Thank you.
Try Philips codes. Philips and Magnavox shares the similar circuit, and firmware. Try these sites to get codes for both.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 10, 2014 | Televison & Video
I need to program a remote for a philips magnavox tv and need codes
Hello
Setup codes to check with Magnavox TV to Magnavox remote control are:
002 009 109
118 209 309 402 408
502 508 510 807 914 917
OK.
Nov 06, 2011 | Philips Magnavox Learning Universal Remote
I'm having problems programing my Philips RC19041006/01 remote that came with a Philips 15pf9936/37 15" LCD TV to work on a Magnavox MDV21001F7 DVD Player
Unfortunately, you will not be able to program your TV remote for the DVD Player. The MDV2100F7 was produced in 2010. Your Philips TV was has a manual with a copywrite date of 2003. Other documentation on the Philips site is from 2004 and 2006. (I am assuming that the MDV2100F7 is your model since no MDV21001F7 is listed at Magnavox or Funai (which made the unit).)
The codes in a universal remote control are only for devices released 6 months or more before the remote was programmed. A DVD player released 4 years later is likely to have a different set of control frequencies.
You need a newer remote or control everything with separate remotes. I wish that I had better news for you.
(The manual for the Philips TV is available from the Philips product site. For the Magnavox DVD player documentation, see the Magnavox (http://www.magnavox.com ) site or the Funai support site (http://www.funai.com/us ). At Funai, search for the model number but leave off the brand. They make units for a number of brands.)
Oct 04, 2011 | Philips Rc1904100601 Remote Control
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
