Question about Kitchen Ranges
I have a brand new 3000i generator and it will start, then run for a few seconds and then cut out when I move the choke to run.
Two things, (assuming it is not a Kitchen Range, but a 3kW petrol driven alternator). Don't start it with the load connected. Let it run for a short while on choke; until it starts to run rough a bit, then put the choke to the run position.
Posted on Apr 01, 2011
Why does troybilt generator engine keeps shutting off when throttle is moved from choke to run position?
Give it a shot of starting fluid. If it runs initially, then most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 05, 2014 | Briggs Stratton Portable Generator 305cc...
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
Was running fine ran out of gas. put in new gas runs for a while then starts sputtering and cuts off. if you move to partial choke it will keep running. air filter is clean
Hi, the carby has picked up some contaminate from the empty tank. The carby will need to be taken apart and blown out. Hope this helps, regards Phil.
Aug 29, 2011 | Coleman Powermate Powermate 5000W...
Have a Honda EM5000S generator issue. Will start easily, run for a few seconds, then cut off. Problem just started. Checked spark plug, air filter, fuel line. All fine. Any ideas would be appreciated.
I sounds like it might be the low oil shut off. it has a bypass that allows it to start but then cuts off after a few seconds. even if the oil is fine the sensor may be bad.
Aug 10, 2011 | Mi T M MiTM 6000 Watt 13hp Honda generator
WHEN IT IS PUT UNDER A LOAD IT WILL NOT STAY RUNNING UNLESS YOU LEAVE THE CHOKE ON
Possible that the engine is not getting sufficient fuel for running and so the choke action is needed. You need to check if the oil switch is cutting off the power, - if so replace oil.
Secondly the fuel settings might need a check up. You might need to clean/reset the plugs/spark gaps and also overhaul the carburator to solve this issue.
Jul 08, 2011 | Honda Electrical Supplies
I have an aldi powercraft generator pc3200dv/10 i can start it but it cuts out after a few minutes ,i am finfding it hard to find the fuel valve also it runs for the few minues with choke on but if you...
Hi there, YES manual VERY misleading, starting it all revolves around the Choke, if I remember correctly, place lever on Choke, start then move lever to on position, good luck
Dec 30, 2010 | Electrical Supplies
Brand new husqvarna 445, won't start
Try not giving any throttle when first starting. The newer trimmers are this way many times. (Maybe the newer chainsaws are this way now.)You prime the carburetor, set the choke and pull, but don't throttle until it runs for 10 or 15 seconds.
Jim
Jun 03, 2009 | Husqvarna Garden
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
