Question about Eddie Bauer Watches
I want to purchase replacement watch bands for my Eddie Bauer watches. Is there a place on line to order watch bands specificly for Eddie Bauer watches?
  • 4 Answers
SOURCE: Eddie Bauer watch.
these watches are waterproof so the stem is screwed down to seal out water. Try turning the stem to unscrew it somewhat , then pull out the stem to set.
Posted on Aug 04, 2008
escapement
  • 2334 Answers
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
  • 16 Answers
SOURCE: get the back off my eddie bauer watch
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on amazon.com or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
Posted on Jan 23, 2009
SOURCE: eddie bauer ibeam watch
If your watch is the same as mine, push the mode button 4 times, which will put you in the alarm menu (AL 1). Then, push the ST/STOP button until "chime" disappears.
Posted on Mar 02, 2009
Looking for an 18k Mens Pasha replacement band
You can replace this band with any other leather band that will fit the mm specifications of the watch.
If you are familiar and comfortable with eBay, you can order a band off of eBay. However, the only way to buy a watch band and be sure it is authentic Cartier is to buy it directly from Cartier or an authorized dealer.
Nov 08, 2013 | Cartier Mens Santos 18k Gold and Steel...
I need a new casing and band as mine is corroded on the sides. Where can I order or collect? Thanks
New case is not going to happen. New band can be purchase anywhere practically unless your band is specific to the watch. Then you will have to go to the manufacture and most likely it will cost as much as you paid for the watch. There is a lot of supposition in my answer as you haven't disclosed what watch you actually have.
May 23, 2011 | Watches
CWhere can I purchase different color watch bands? Or if my band goes bad our their replacement bands available? Cheryl
You go into any watches/jewelery store or watches sections in department stores or buy on-line (search "watch straps" or "watch bands")
Feb 19, 2011 | Watches
The leather band is broken on my Skagen 324LSLB watch. How do I get another band for the watch?
Go to http://www.skagen.com/chooseRegion.fx choose your regiion and then scroll down to the bottom of the page where you will see "customer Service".
Click on this and then on the left you will see under "About ouR Products" you will see "repairs".
Click on this and an order form will appear which will allow you to order the strap you need.
Jan 05, 2011 | Watches
Need a new watch band
mcdevito75 here, Ebay is a great place for your watch band, but you should know the watch band size in MM, or you can look for a small watch repair shop in your area.
Jun 17, 2010 | Locman Titanio Tonneau LOC/484/CRBRD/BK...
Cannot get the back cover on my eddie bauer watch after replacing battery
Watch makers/technicians use a special press to replace the back. You can get these presses but the cost can be more than it is worth.
Since the watch is most likely water resistant and you will have to go to a watch maker/technician to replace the back anyway I recommend having the rear seal inspected and replaced if needed and having the watch pressure tested to be sure that it is sealed to factory specifications.
Sep 24, 2009 | Watches
Eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Aug 06, 2009 | Watches
Get the back off my eddie bauer watch
Jan 16, 2009 | Timex Expedition 84601 Wristwatch
Can't set time on my Eddie Bauer watch
Nothing on the net, so, you will have to go back to the store.
Sorry....
Dec 20, 2008 | Watches
Eddie Bauer watch.
Jan 05, 2008 | Watches
Watches Logo
770 people viewed this question
Top Eddie Bauer Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Eddie Bauer Watch Expert? Answer questions, earn points and help others
