Question about Cameras
Every time I turn my camera on and off I have to reset the picture settings. How do I keep the settings the same,until I manually change them?
  • Cameras Master
  • 17,129 Answers
Possible there are errors in the CPU of the camera and so does not respond to the commands of the menu.
Usually this is an auto save mode and if this wont stay then is is possible that the processor has prroblems.
Request you to clean battery terminals, check card, check of moisture- use a hair dryer to heat off.
Posted on Apr 01, 2011
Won't take a picture and keep the time in the memory
You have a button that is stuck or the battery has an issue.
Feb 01, 2013 | Wildgame Innovations IR 2.0 Digital Game...
Using timer
Kodak EasyShare C613
Changing picture-taking settings
You can change settings to get the best results from your camera.
1Press the Menu button.
2Press to highlight a setting, then press OK.
3Choose an option, then press OK.
■Press the Menu button to exit the menu.
NOTE: To better understand each menu option, use camera Help. Highlight a menu choice, then press the button. Some settings remain until you change them; others, until you change modes or turn off the camera. Some modes offer limited settings.Press Menu, , and OK to access settings
Options
Self-timer
10 seconds (default)—
so you have time to get into the scene.
2 seconds—
for a steady, auto-shutter release on a tripod.
2-shot—
one picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
Exposure Compensation
Increase or decrease brightness before taking a picture. (Also see page 27.)
0.0, -0.5, -1.0, -1.5, -2.0, +0.5, +1.0, +1.5, +2.0
From: http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00711/C613_UG_GLB_en.pdf
If this helps, please post a rating for me. Thanks!
OpenSource13
Apr 19, 2009 | Kodak EasyShare C613 Digital Camera
Selected resolution will not save
You need to change the setting in the Menu of ALL RESET from ON to OFF so that it will retain any setting changes that you make. To do this Press Ok button - right arrow to Mode Menu - down arrow to Setup tab - right arrow to All Reset - right arrow and choose Off and then press Ok. This will retain the mode setting until you manually change it again or change all reset back to On.
Aug 21, 2008 | Olympus Camedia C-350 Digital Camera
Camera still possessed
There is something wrong with the settings of the camera.
When it is on setting or view mode is fine. It is not supposed to take pictures.
Go thru the Menu and pick the way you want your pictures, size and all those details, switch them take pictures and keep switching the settings until you get it right.
My camera was taking 3 pictures at the time, and it was because of the setting was set to do that. Don't be afraid of changing the setting for pictures, you can always change and try different things, digital pictures can be erased right away. So you can try as much as you want.
Try all options in the setting for taking a picture, change a setting, try to take a picture and see what happens. Then try on another setting and so on.
Artgirl
Jul 08, 2008 | Nikon Coolpix 2100 Digital Camera
Pictures too bright
This has happened to me also. You mention that you were changing settings. The symptoms sound like your camera is in a special setting other than "Auto". Examples that would produce such results include Fireworks or Manual. Recommend trying to change your settings one more time:
1. Turn the camera on, and press the FUNC/SET button.
2. Press left or right on your circular dial switch until "Auto" is selected.
3. Press the FUNC/SET button one more time to set the camera to Automatic.
Now take a picture to see if this fixed it.
May 11, 2008 | Canon PowerShot SD600 Digital Camera
The flash on my camera is not working!!!!
If the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
Hope this one helps.
Jan 12, 2008 | Samsung Digimax S630 Digital Camera
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
Turn off camera after the settings
have been changed to refresh the camera.
Dec 23, 2007 | Samsung Digimax S630 Digital Camera
Camera will not keep date settings
I suggest u to contact the service people and they will change the internal battery to keep update with time and date. Every camera has internal small battery so has to change regularly
Dec 18, 2007 | Fuji FinePix E550 Digital Camera
The Flash on my camera won't work
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
Dec 13, 2007 | Samsung Digimax S630 Digital Camera
Using flash freezes up camera
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
If it still does not work, you need to contact the Manufacturer.
Dec 12, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
22 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
