Question about Sony Cyber-shot DSC-S700 Digital Camera
I want to make a video but I'm not sure what buttons to press or how to do it.
  • 455 Answers
For capturing movies in the Camera, turn the mode dial of the Camera to the Movie position. Click here to open the handbook Manual of the Camera. Refer to page # 18 of the manual for the information on selecting the movie mode for shooting movies using the mode dial.
Thanks for using FixYa.
Posted on Apr 01, 2011
How do transfer pictures from internal memory to card?
Got this from the manual.
Copying pictures/videos
You can copy pictures/videos from a card to internal memory or from internal memory
to a card.
Before you copy, make sure that:
? A card is inserted in the camera.
? The camera’s picture storage location is set to the location from which you are
copying.
Copy pictures/videos:
1 Press the Review button, then the Menu button.
2 Press up and down arrows to highlight Copy , then press the OK button.
3 Press up and down arrows to highlight an option.
4 Press the OK button.
Apr 14, 2010 | Kodak V803 Digital Camera
We have a Magnavox VCR/DVD player. When pressing the VCR/DVD button it will not switch from VCR to DVD.
I have found this to be a problem with my Magnavox MWD2205. It seems to be a problem that Magnavox (actually FUNAI CORP.) can't seem to understand and fix on their machines.
1. Pick up your remote and press the video button.
2. Press the DVD button.
3. Press the Video button.
4. Press the DVD button.
That simple. This usually works but no guarantee.
Also check on the back of you player and see what cable you have connected. Often times S-Video will be plugged in and so VCR won't function. Or VCR composite video (the little yellow round port) will be plugged in and so your digital DVD won't function either. Make sure that whatever media format you choose that your ports correspond with the chosen format.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
How do I delete videos
You can remove the videos by:
1. Open Videos.
2. Select Camera Videos.
3. Select a video.
4. Press and hold the Center button.
5. Select Delete, or to remove all the videos, select Delete All.
Or you can wipe the entire iPod by:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jan 12, 2010 | Apple iPod nano
When I play my videos, that i had just made, the sound is very low. How do I fix it
make sure when you take a video you adjust the volume first so then you will have the sound you want..press the mode button to access in audio mode with the arrow buttons then press ok button. in the audio mode to selct the voice recoding file you want to play press ok button to start playback of the voice recording file thru vivicam speaker..good luck hope this give you an idea somewhat..
Nov 30, 2009 | Vivitar ViviCam 5340s Digital Camera
My Onkyo Tx-Sr700 sound is not working. I have speakers connected for surr. sound but I can't figure out what buttons to press to turn them on for tv. Tv is video 1
make sure you have audio cables connected from your cable providers audio out to your receivers audio in on video 1 press the video 1 button you should hear the sound.
Oct 16, 2009 | Onkyo TX-SR700 Receiver
Have a toshiba 27df47 flat screen tv. how do you
First make sure the video inputs are not locked using these instructions:
To set up the video lock:
1. Press MENU, then press or to display the LOCKS menu.
2. Press  or to display the password entering mode.
3. Use the Channel Number buttons (0-9) to enter your password,
then press ENTER. The LOCKS menu appears.
4. Press  or to highlight VIDEO LOCK.
5. Press or to select:
• OFF: Unlocks all video input sources.
Then it appears that choosing Video 2 using the TV/VIDEO button should enable the front input.
An entire manual is avialable here that should closely match your tv:
http://www.tacp.toshiba.com/tacpassets-images/models/27DF46/docs/27DF46_om_E.pdf
Aug 29, 2009 | Toshiba 27DF47 27" TV
I forget the exact steps for the remote to record from my video camera to dvd recorder
You have to plug the video cam into the front ports of the Magnavox.
Then press the Setup Button
Go to Required Settings --> OK
Video Input --> OK
Go to E2 --> make sure it says "video in," unless you are using an S-Video connector --> OK
Press Setup
Start playing from Camcorder and make sure that you can see the picture on your TV screen.
Press REC on the Magnavox
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Olympus sp510uz no sound on video
From SP510 camera switched off:
1. Turn dial on top plate to movie mode (selections from the menu screen apply to the mode the camera is set in);
2. Switch on SP510 power;
3. Press "MENU" button on back plate;
4. Select "Camera Menu" from screen if not already on it, using navigation buttons on back plate
5. Scroll down yellow "Camera menu" tabs to microphone picture (below "Digital Zoom"), which may be showing "off". Select OK and toggle yellow tab from "off" to "on", then press OK button.
6. Microphone tab should now show "on".
7. Return to main menu (press MENU button).
8. Return to image screen (press MENU button).
9. Test to see if video now records sound.
10. If is still doesn't record sound, try "reset" from video menu screen (this will reset the movie mode to factory settings, including microphone on).
Dec 21, 2008 | Olympus SP-510 UZ Digital Camera
Bypass code for the dual 8181 cd player
For the Anti-Theft Passcode if you forgot yours - Turn to player on. Make sure the screen is out. Press and HOLD the MUTE button. While holding the MUTE button, press and HOLD the POWER button. (Should be holding them both down at this time.) After about 12 seconds a new passcode screen should come up. Release the MUTE and POWER buttons. Type in 122164. Press OK. Your passcode is now reset to 0000.
For The E Brake Passcode - Put in a DVD. Wait until you hear the sounds of the DVD. Press STOP twice on your remote. Press 22604 on the remote. Press OK/ENTER on the remote.
Nov 09, 2008 | Dual XDVD8181 Car Video Player
Need to delete memory
You need to remove the memory card from the camcorder and place it into a pc or photo shops computer. This will allow you to view the saved items on the memory card. You can then save these to disc and delete the contents on the card.
Jun 12, 2008 | Optimus DV-5040 Camcorder
Sony Cyber-shot  DSC-S700 Digital Camera Logo
44 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
