Question about Panasonic CQ-C8100U CD Player
Scooter stereo ok so yes it is the 15 amp fuse on the deck itself. i bieleve i have all of the systems connected corectly. how would i fix the problem you were saying if it were connected backwards. also is there anything else it could be. In one of the posts i gave you the battery that i am hooking if up too is that a bad battery to use. also i am connecting it directly to the battery. is that bad?. please let me know so i can get this all done and on the road
  • wilson756168 Aug 05, 2008
    i cant even bieleve it i am so stupid....i blew like 15 fuses and finaly realized that i had the wires backwards. negative to positive and so on......i got it fixed and the deck turns on...thanks a ton
    Brigadier General:
  • 6,966 Answers
As long as the battery is 12volts then it should be ok. Since you have verified that the yellow and red are wired to the positive terminal and the black is to ground, fuse blowing would indicate that there is an internal short in the unit. You need to open it up and follow the yellow wire where it leads to and check the surrounding components.
Does the fuse blow when just connected or when powering it up?
Posted on Aug 05, 2008
How to connect speakers to A technic SL7 TURNTABLE RECORDPLAYER
The turntable goes into a Phono preamp in a amp or receiver then the amp or receiver will have the terminals for the speakers. The Turntable by itself can not drive speakers. It is a part of a stereo system.
May 09, 2014 | Audio Players & Recorders
The stereo, some times is turn off, and some times work perfectly. I guess than problem is conected a wire with 10 amps. The stereo have a fuse 15 amps. Could you help me. please. sorry my english nots...
No, its ok. Try to check the wire connection in the power supply. Check the fuse if the spring that pushes to contact is still working. The problem is on that area.
Nov 10, 2010 | Alpine CDA-9811 CD Player
Is there a fuse for the electrical system?
yes, it is generally located in the same compartment as the battery. Typically, it will be rated as 15 amp. This fuse does not protect the starter though.
Aug 17, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Amps ? stereo intergrated amps ?
Since the mixer has a line level output, yes you can use a home stereo for the "AMP". Use the AUX IN, TAPE IN or CD IN on the stereo and connect the speakers as you normally would.
Dan
Feb 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
1989 Licoln Town Car Audio system stopped
depends on whether u installed an amp for the door/dash/rear speakers or not or if it came with a factory amp for these speakers. fuse box is in 1 of 3 places, 1 under the driver side dash, 2 in the glove box, 3 on left side of dash. also if this stereo is not factory u might want to check the fuse on the stereo itself to see if mayb it has gone out or has burned the outputs.
Mar 17, 2009 | 1995 Lincoln Town Car
The protect light stays on
is your amp grounded well?
are all of your fuses fine?
connections to stereo?
if all else fails you might have blown your amp like mine, you can see about getting it fixed but i just found another one.
how many watts is your amp? how much does your sub need?
Nov 18, 2008 | Pyle - Elite: 2 Channel 1800W Elite Series...
Deck
According to the owner's manual, the "deck" message means that your trunk is open. If your trunk is indeed closed, try opening and closing it a couple of times to see if it's not closing all the way due to an obstruction. If all this fails, you may have a bad fuse or connection that makes the computer think that the trunk is still open. Hope that helps!
Sep 09, 2008 | 1997 Chrysler Sebring
Scooter stereo
Hi again,
My apologies, missed the connection. Now I remember, must be really getting old.
Back to your concern, which fuse pls? the 15 amps for the Panasonic or the amp"s fuse.
Incidentally, even if the speaker wires were wired incorrectly, that would not cause the fuse to blow. The only way the fuse would blow is if the unit was connected with the polarity reversed, even just once. Internally, most units have a reverse protection diode and/or regulator that would short circuit itself. Thereafter even if it were wired correctly to the battery, the fuse will always blow.
Looking forward to hearing from you.
Aug 05, 2008 | Panasonic CQ-C8100U CD Player
Connect 5 piece Sony seperates stereo system
OK, this is pretty easy to do. First connect your leads from the component outputs(i.e., tape, cd, phono, etc) to the recievers corresponding input for the device. Then connect the recievers outputs to your equalizer, if it is a seperate eq. Then the outputs of that to your amplifier, then your speakers to that. Be sure all of your wires are connected with the proper polarity. These instructions may be a little different for your exact setup but basically follow the same order minus any device you dont have.
Feb 03, 2008 | Audio Players & Recorders
Panasonic CQ-C8100U CD Player Logo
152 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
