My samsung wa75b7pt does not wash just hums - Washing Machines
Hi myne washes but when it come to the rinse and spin it hums. If I take out all the water and only have a few items in it will spin. What can I do?
Posted on Nov 04, 2012
  • Washing Mach... Master
  • 17,129 Answers
Possible that the motor is jammed as the motor is faulty or the main spindle drive is jammed. If so release using a de-greasing spray , manually turn to see if the shaft is moving freely. if not remove and reset.
Also the failure of the motor capacitor can cause the motor to hum. replace and check.
Posted on Apr 01, 2011
2 Suggested Answers
news775
  • 699 Answers
SOURCE: How do you take out the drum of a samsung Wa75b7pt
Do not take drum out.
Run a wash without clothes in and put a mild bleach solution inside.
Posted on Feb 07, 2011
Samsung WA75B7PT won't drain. Pump is working, impeller is spinning, but no drainage. What could it be?
My guess is the is a blockage in the pipe. You may need to take it outside, remove any access panels on the rear and manually pull of the hose to the drum and from pump to outlet and see what happens. Try flushing the lines with a garden hose if you can. Take care if you have to do this indoors or out, electricity and water don't mix!! Be prepared to catch any drained water if indoors.
Feb 16, 2016 | Samsung Washing Machines
Filter wa75b7pt
that does not sound right
Feb 12, 2014 | Samsung Washing Machines
Top loader not spinning
May have lost motor, belt, clutch, fuse, many different things can be the cause. Do you hear the motor running?
May 11, 2013 | Washing Machines
How do you take out the drum of a samsung Wa75b7pt top loader washing machine i want to clean it
Feb 07, 2011 | Samsung Washing Machines
How to fix a machine that does not pump out the water
most likely pump is not working it is just behind where the drain pipe comes out of the machine.you can remove it to see if its not working . the impellor inside may be damaged
Jul 19, 2009 | Washing Machines
Samsung Silvercare hums, but does not run
FIXED!!!! amen. Attached to the back of the washer was a plastic bag with a tech spec pamphlet. Inside the pamphlet were instructions for running tests via the front control panel on the various cycles to weed out the problem -- fill, spin, drain, etc. The test failed on the draining section citing a problem with the drain pump. So long story short and MANY towels later, I found a small finishing nail in the motor. I had removed the hoses thinking there might be a blockage, but found nothing. So I removed the motor and washed it out. Nothing odd there. So I took the front off the motor and found the nail. It somehow made it through the drain holes in the washer drum but got stuck in the motor.  Thank you Samsung for taping the tech manual to the back of the washer. I could not find it anywhere on the web for this model. After discovering the testing available via the contol panel and the simplicity of the machine, I love Samsung.
Apr 01, 2008 | Washing Machines
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
